Old 10-02-2016, 04:36 PM   #1
groovzilla's Avatar
1966 20' Globetrotter
Seattle , Washington
Anybody have a 1965 24' Tradewind Wiring Diagram??
All,
Does anyone have a copy of a 1965 24' Tradewind wiring diagram?? including both 12v and 110v house wiring??
Thx in advance
groovzilla is offline   Reply With Quote
Old 10-02-2016, 04:53 PM   #2
1965 26' Overlander
Walhalla , South Carolina
Originally Posted by groovzilla View Post
All,
Thx in advance
I have a 1965 Overlander diagram if that would help, it would be Monday before I could get it. A quick Google search for Vintage Airstream wiring Diagrams will find most of them.
DougW
DougEW is offline   Reply With Quote
Old 10-02-2016, 08:11 PM   #3
groovzilla's Avatar
doug i've searched the internet and i can't locate a 1965 diagram - if you could post a link of your diagram or email me that would be great
Old 10-03-2016, 04:46 PM   #4
1965 26' Overlander
1965 AS Overlander International Wiring diagrams from the original manual. If a cable has 2 wires it's usually 12v, 3 wires 110 ac, your main entry cable if it hasn't been updated was aluminum wire which you should changed.
DougW
Name:	AS elec pg 11-B2 001.jpg
ID:	272796   Click image for larger version
Name:	AS elec pg 11-1A 001.jpg
Name:	AS elec pg 11-B 001.jpg
ID:	272798   Click image for larger version
Name:	AS elec pg 11-1 001.jpg
Old 10-03-2016, 04:47 PM   #5
1965 26' Overlander
Ok that was special they imported upside down.
DougW
Old 10-03-2016, 11:24 PM   #6
groovzilla's Avatar
doug thank you so much!!
Old 10-04-2016, 07:50 AM   #7
groovzilla's Avatar
doug - the previous owner removed the univolt from the trailer and also most of the bathroom leaving only the tub - circut breaker box is intact along with the wires leading out of it - there are (3) 110v(house)wires in the rear that are capped including a 12v red/black wire.
would it be possible for you to take a photo of the univolt in your trailer so i can get some idea of the wires that are leading into it??
Old 10-04-2016, 08:40 AM   #8
groovzilla's Avatar
here are photos of the wires in rear of my trailer - *also in last photo what are the small cut gang of wires and switch for?
ID:	272863   Click image for larger version
ID:	272865   Click image for larger version
Old 10-04-2016, 10:31 AM   #9
1965 26' Overlander
I restored mine over the last few years and changed out the Univolt and most of the rear wiring. I added a stand up shower and gray tank but keep the rest original. Might be a Univolt only page. There was a small red/black that went up to the battery monitor but most of the 12v was blk/white house wire.
DougW
Old 03-06-2017, 08:35 PM   #10
Caroyl's Avatar
1964 26' Overlander
Warner Robins , Georgia
Bookmarked
Caroyl & Tim
1964 Overlander "Gracie"
WBCCI # 31088
2009 F-150 "Big Red"
Caroyl is offline   Reply With Quote
Does anyone have a stab jack switch wiring diagram? stefario Jacks, Stabilizers, Lifting and Leveling 6 08-26-2012 04:19 PM
Does anyone have a wiring diagram for a '68 safari?...Please HolyRoller Batteries, Univolts, Converters & Inverters 1 05-11-2011 09:45 AM
Anyone have a wiring diagram for '75 excella? MonaxLisa Electrical - Systems, Generators, Batteries & Solar 13 03-27-2011 12:54 PM
Anyone have a Wiring Diagram? Chopper Electrical - Systems, Generators, Batteries & Solar 14 09-22-2006 09:49 AM
