Old 04-15-2007, 03:11 PM   #1
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Another nifty L.E.D. product
Just got done doing some resealing in the Excella shower. We have a center bath and the shower has no lighting which is good or bad depending on how you look at it. Decided we needed a light and found this. Got it on eBay (see link). The unit is all plastic and completely sealed. Mounts with screws or the attached adhesive pad(peel & stick). It's L.E.D. and bright. The housing diffuses the light to make it omni-directional. I'm adding a magnetic reed switch underneath so that I can turn it on with a small magnet and not worry about an exposed switch in a wet environment.
eBay Motors: JUMBO High Powered 24 White LED Dome & Utility Lights (item 260106723694 end time Apr-13-07 12:46:23 PDT)
ID:	35641   Click image for larger version
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 04-15-2007, 04:12 PM   #2
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
Great idea. Thanks for sharing it.
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WDCU
SilverRanger is offline   Reply With Quote
Walbernize? 68 Suburban Cleaning, Stripping & Polishing 19 10-10-2012 08:35 AM
L.E.D. 4" conversion w/extras Excella CM Lights - Interior & Exterior 9 06-06-2010 10:53 PM
Water Leaks? - New Repair Product COArgosy78 Plumbing - Systems & Fixtures 10 05-27-2008 01:22 AM
LED tail light conversion Excella CM 1978- 1979 Excella 500 0 06-13-2006 09:38 PM
Aluminum underbelly missing Joe C 2002 - 2005 International 10 11-10-2002 09:41 PM
