Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 09-03-2008, 06:33 AM   #85
wannaroam
wannaroam's Avatar
Profile:  1978 31' Excella 500
Harmony , Pennsylvania
Images: 34
John
We bought this 2 years ago and have been working on it ever since.
Thanks again guys.
wannaroam is offline   Reply With Quote
Old 09-03-2008, 08:05 AM   #86
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Originally Posted by wannaroam View Post
We are in the final stages of getting our unit on the road. My husband was hooking up the lights and brakes - he had to run the wiring for the truck as there wasn't a towing package on it. But we have hit a snag.
When we brought this home all we had working was the clearance/running lights. When he started yesterday it was the same thing; after some cleaning and removal of the rear lens caps we found a few bulbs gone. He was short of bulbs but used a couple he had and we had all the lights on and working except for the very outside running lights at the rear brake/turn/running light section. He went and bought new bulbs and put them all in. He also replaced the three front clearance lights.
He then wired up those two outside rear lights to the rear running lights since some PO had cut the wires to them (green wire) and then nothing worked. He went back and disconnected those two lights and we still had nothing. Hmm. With some messing around we finally got the clearance lights and the back up lights to work but when we put the left turn signal on all four lights flash. When we put the right turn on it works normally.
We are not finding any juice now on the red wire for the left turn signal, but when doing a continuity check from this wire to the front it is fine.
Additionally, when we put the working turn light on the tow vehicles turn lights dim.
After reading on this forum I personally went and checked to be sure that the bulbs were the correct ones and in the correct places. If my husband has them right - with single filament in four places and only double filaments at the turn signals.
Summer is almost gone, and I am so close to getting this on the road, but we have now lost almost all weekend and still are no further with the light situation.
I am all ears for some help.
If you don't already have one, I would suggest you purchase the service manual for your year Airstream.
It covers many subjects as well as detailed wiring diagrams, including the wire colors.
Helps second guessing with everything about the trailer.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 09-03-2008, 08:42 AM   #87
someisgood
Profile:  1973 29' Ambassador
Wow, that's pretty weird. You know what ? I would head for an expert at this point. You need an experienced RV technician to sort this out. Doesn't have to be an Airstream person, as these systems are more or less the same in all RV's.
I would still start at the truck, check ALL the connections. You will need to take the plugs apart, yes even if they are new, to see that they are OK. Then you need to do the same, checking continuity on each circuit all the way back to the trailer. Your running lights should not be on the same circuit as your battery, but your battery does get charged by the Tow vehicle. The wire colors previously described are the same as my '73.
I doubt the problem is in the walls unless there has been damage or a major leak.
Another thought, make sure the ground on the tow to trailer is correct, one of those connections should be ground.
Finally, take a short piece of wire, strip both ends, and go between the socket and the metal back of the light, or even the housing.
12 V weirdness is nearly always a missing ground.
Good luck
someisgood is offline   Reply With Quote
Old 09-03-2008, 10:38 AM   #88
mustang
mustang's Avatar
Profile:  1971 31' Sovereign
Kent , Ohio
Wannaroam I am wondering how the inspection went ? not to be nosey.
mustang is offline   Reply With Quote
Old 09-03-2008, 03:06 PM   #89
wannaroam
wannaroam's Avatar
Images: 34
Everything is connected and working fine and the inspection is tomorrow AM.
mustang - I will be sure and let you know what happens.
Andy - we actually do have the manual, and you're right, it is invaluable and we would never have gotten anything done without it.
But, for when something does not go the way you thought, nothing beats this forum!
Old 09-05-2008, 02:53 PM   #90
wannaroam
wannaroam's Avatar
Images: 34
Yes!!
And our AS is officially INSPECTED!!!!!
Old 09-05-2008, 08:34 PM   #91
richinny
richinny's Avatar
Profile:  1994 34' Limited
Westchester Cty. NY , & Miami FL
great!
Ricky
Ingrid - my unofficial '"World's Oldest Airstreamer"
January 1909 - October 2008 R.I.P.
Old 09-05-2008, 09:49 PM   #92
69AmbassFl
Profile:  1969 29' Ambassador
orange Park , Florida
Congratulations, I hope you enjoy it this weekend!!!
John
69AmbassFl is offline   Reply With Quote
Old 09-05-2008, 09:57 PM   #93
purman
purman's Avatar
Profile:  1968 28' Ambassador
Cedaredge , Colorado
hope you do to..
Jason
2008 5.7 L V8 Sequoia w/tow package (dark green)
'89 Jaguar XJ6
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-06-2008, 07:29 AM   #94
wannaroam
wannaroam's Avatar
Images: 34
Thanks! But we decided to wait until next weekend. I go to school and had a make up day on Friday, and there are lots of little things yet to do.
Next week my school will end on Thursday at 11:30 and we will leave Thursday night, a bit more prepared than we would have been yesterday.
I have to say as pretty as they look in your driveway, they look so much prettier going down the road! (After 2 years of driveway sitting).
Old 09-07-2008, 05:30 PM   #95
DEITZ645
DEITZ645's Avatar
Profile:  2006 30' Classic S/O
1987 34' Excella
Mohrsville , Pennsylvania
Images: 84
Yes They Do
I am glad to hear your inspection went off without a hitch. I can't wait to see your trailer when you come up to Penn Wood.
Carl, Elaine & Bailey Beagle
2006 30' Classic W Slide & Limited Package
1987 34' Excella 1000
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
AIR #14487
WBCCI #7429
DEITZ645 is offline   Reply With Quote
Old 09-14-2008, 11:57 AM   #96
69AmbassFl
Was your weekend trip worth the 2 year wait? Hope you both had a Great time!
John
Old 09-14-2008, 05:46 PM   #97
wannaroam
wannaroam's Avatar
Images: 34
you bet!
We went to East Harbor State Park and despite it raining almost non-stop from the time we arrived until the beautiful sunny Sunday morning that we left, yes, we had a great time.
It was out first time to meet other AS'ers and just like in the forums they were a gracious, friendly, and helpful group. Even though we came virtually empty handed we were treated to a wiener roast Friday night and a smorgasbord of food at the pot luck on Sat. night.
I can't wait to go on another outing!
Old 09-14-2008, 06:36 PM   #98
loudruff
Profile:  1978 Argosy Minuet 6.7 Metre
Lorain County , Ohio
You did it!
We were very glad to meet you too! We have been watching your adventures on the forums! We will be glad to see you again soon.
Lou
CP: W/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
AIR#2695
loudruff is offline   Reply With Quote
Skylight Dilemma moosetags General Interior Topics 6 04-25-2008 12:39 PM
VIN Dilemma DasAir Title, VIN & Registration 3 04-07-2008 07:36 PM
Rear Window Dilemma Julison 1969-1971 Caravel 2 10-02-2007 09:34 PM
Antenna Dilemma balrgn Electrical - Systems, Generators, Batteries & Solar 5 07-06-2005 10:42 PM
Seat Belt Dilemma 77Argosy28 Interior Restoration Forum 4 07-26-2004 03:52 PM
