Old 09-01-2008, 10:37 AM   #43
richinny's Avatar
2011 34' Classic
you need an adapter that takes the separate turn signal voltage from the tv and sends it to the trailer, without letting it come back and back feed to the tv brake lights. i think it uses an electrical 'valve' called a diode.
Light Converter w/ 4-way Flat Plug (for vehicles with separate brake light and turn signals) DT119130...$21.95
Ricky
Old 09-01-2008, 10:46 AM   #44
RBolton's Avatar
Belington , West Virginia
Is there a "known good" trailer available that you can connect your tow vehicle to? Or for that matter another TV that you can hook to your trailer. This could save a liitle time in determining if the problem is with the TV or the trailer and keep you from barking up the wrong tree.
RBolton is offline   Reply With Quote
Old 09-01-2008, 11:08 AM   #45
wannaroam's Avatar
1978 31' Excella 500
Harmony , Pennsylvania
Images: 36
richinny
I don't have the tv light problem; that was another post from someone else.
I think that we have the light issue solved we just need to have the correct connection to transfer the 5 way plug of the truck to the 4 way plug of the AS.
wannaroam is offline   Reply With Quote
Old 09-01-2008, 11:09 AM   #46
1969 29' Ambassador
orange Park , Florida
Rickys got the part, just have to cut the flat plug off and wire it to the truck between the lights and the 7 way. It should come with instructions and just test the lighting before you button it up.
69AmbassFl is offline   Reply With Quote
Old 09-01-2008, 11:20 AM   #47
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
That is the converter thing I was talking about last night Wannroam. I was wondering if you got it yet. I hopefull you get it on the road, here. I predict a test drive here real soon.
mustang is offline   Reply With Quote
Old 09-01-2008, 11:39 AM   #48
wannaroam's Avatar
Images: 36
Ok, I am on my way out to get one........cross your fingers.
Old 09-01-2008, 11:59 AM   #49
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
Good Luck.
Old 09-01-2008, 12:24 PM   #50
Gainesville , Florida
May sound stupid, but is the tv running? Some vehicles have no brake lights without tv running. Rest of lights may work. Shot in the dark...zz
Old 09-01-2008, 01:44 PM   #51
wannaroam's Avatar
Images: 36
And on to the next problem....
Right now the center of the 7 prong on the trailer was wired up for the new electric brakes.
Where do you then put the brake wire coming from the truck?? A flat 5 has no spot for a brake....
Old 09-01-2008, 01:53 PM   #52
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
dont run the electric brake controler thru the device it is only for lights
Old 09-01-2008, 02:27 PM   #53
wannaroam's Avatar
Images: 36
then how do you get the electric to the brakes?
Old 09-01-2008, 02:46 PM   #54
1969 29' Ambassador
are you still using the 7 pin connector? Do you have an electronic brake controler mounted under dash? The center pin is usually wired for the battery charge from the tow vehicle,but doesn't really matter. The electric brake are controlled by a controller and is wired from it to the connector through a wire ran from inside the veh.
Old 09-01-2008, 02:58 PM   #55
RBolton's Avatar
I think this device is meant to be wired between the tow vehicle rear lamp wiring and the 7 way connector on the tow vehicle. It provides separate wires for the signals and the brake lights. After wiring your tow vehicle rear lamp wiring into the side of the converter with five wires, cut off the four way plug and connect these wires to their corresponding terminals on the TV seven way connector. You will still connect your tow vehicle to your trailer via the 7 way connector.
I think there is only about a 50/50 chance that this is your problem though. That is why I made the earlier suggestion that you find a donor tow vehicle to make certain that the trailer wiring is correct.
Your husband is right that he cannot install this converter with out actually having to wire something. Good Luck
Old 09-01-2008, 03:10 PM   #56
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
You put the devisein line. The light wires run thru the device like the schematics say. and they come out the other side on a flat plug. Now, Your 7 way plugin on tow vehicle will either come with the flat plug also and you simply plug them in together or you have to cut the flat plug off the device and connect those wires to your 7 way plug in. You simply run the barke controller to the proper wire on the 7 way plug. I hope that makes sense. It should ahve come with a wireing diagram.
Skylight Dilemma moosetags General Interior Topics 6 04-25-2008 11:39 AM
VIN Dilemma DasAir Title, VIN & Registration 3 04-07-2008 06:36 PM
Rear Window Dilemma Julison 1969-1971 Caravel 2 10-02-2007 08:34 PM
Antenna Dilemma balrgn Electrical - Systems, Generators, Batteries & Solar 5 07-06-2005 09:42 PM
Seat Belt Dilemma 77Argosy28 General Motorhome Topics 4 07-26-2004 02:52 PM
