Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 09-28-2009, 07:38 AM   #1
Profile:
Am I Nuts Or Just Getting Old? Both!?
Nice new batteries and battery shut off switch under the new little storage shelf we made to hide converter etc. But in the process I confused myself and you guys just GOTTA help.
I turn batteries ON and of course I have all 12v stuff operating. I turn batteries OFF. I plug into house current and of course my AC, lamps etc. work normally. But NO 12 volt stuff. Is that right? Seems to me the converter is supposed to take 110 and convert it to 12v when the batteries are OFF. So even when I am on shorepower my 12v stuff should ALSO work.
Have I slipped a cog?
Anniedog is offline   Reply With Quote
Old 09-28-2009, 07:50 AM   #2
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
You can leave the batteries connected while using 12 volt, and connected to shore power. You can disconnect the batteries if you are not going to use the trailer for a few weeks, or months.
(No Longer at Inland RV)
Old 09-28-2009, 08:00 AM   #3
Profile:  1977 29' Ambassador
Brandon , Mississippi
It sounds like the switch is connected between the house and the batteries/converter. I made sure my converter was on the house side of the switch so when I turn off the switch NOTHING is hooked to the batteries.
Although it maybe possible depending on you converter style, I don't use the converter to run the 12v lights unless the battery switch is ON. One multi stage charger I had didn't care to work properly unless there was a battery hooked to it.
Hi Ho Silver RV!
Vernon, Sarah, Mac the Border Collie -
'Epiphany' the 29' Airstream and a honkin' long 34' named AlumaTherapy
Old 09-28-2009, 08:37 AM   #4
FLYNCLD's Avatar
Profile:  1962 22' Flying Cloud
Bend , Oregon
If you are anything like me, the answer is YES!!
The answers you have gotten are correct, just flip the switch
FLYNCLD is offline   Reply With Quote
Old 09-28-2009, 08:57 AM   #5
Lumatic's Avatar
Profile:  1971 25' Tradewind
Estancia , New Mexico
The 120 circuit is a separate circuit from 12v. Your description sounds like your 12v circuits are wired converter to battery to 12v circuits opposed to converter to 12v fuses to battery. The battery disconnect switch is more for long term storage use, to prevent parasitic drains of appliance circuit boards, etc.
Pay no attention to the man behind the curtain- WoZ
Nuts ArtStream General Repair Forum 7 12-09-2007 12:36 PM
Nuts! Dave and Pat All Argosy Trailers 12 10-16-2007 07:53 PM
Are we nuts? pbnjsellers On The Road... 19 06-14-2005 10:05 PM
Am I nuts? Dickwalker Towing, Tow Vehicles & Hitches 3 12-09-2003 10:00 AM
