Old 04-25-2015, 02:17 PM   #1
, North Carolina
Affordable LED strip DIY?
Spring greetings forum folks~ I feel some pride having just converted the two florescent bulbs in the ballast over the sink in my 1981 Execella with two LED 12 inch strips (I know that's no biggy for many here . Now I want to do the rest of the 12 inch ballasts, but at $20 per strip and two strips per ballast that is very costly.
Is it possible to buy a roll of the 12V flexible LED strip lights with adhesive backing and cut them into 12 inch lengths and somehow attach the base with the positive and negative wire (don't know what to call this) myself?
Here's the part I just successfully installed from Out of Doors Mart (who I really like) plus a great short DIY video: LED Warm White strip for repairing 12in light T250mmWW [15751W-05] - $19.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
And here's a roll of the flexible warm light strips I am curious if I can create my own 12 inch strips to install: http://www.amazon.com/Lampux-Flexibl...d+strip+lights
Thanks for any advice!
simple sanctuary is offline   Reply With Quote
Old 04-25-2015, 02:46 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Yes, to your question. YouTube has dozens of videos on how to do it yourself.
MICHAEL
Old 04-25-2015, 02:50 PM   #3
1987 25' Sovereign
Oregon , Ohio
Check out led4rv.com
msmcv51 is offline   Reply With Quote
Old 04-25-2015, 02:54 PM   #4
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
LED Strips
Yes, contact Dan at Contact Us : LEDs 4, Recreational Vehicles
He might be able to help out. Here is one example of a longer strip....
Serenity_Mod_04.20.15-2 by Fantinesvoice.com, on Flickr
This allows me to see what is under the bed. And turns on when I lift the bed.
Happy trails and Good Luck
AIR #31871 WBAC #4165 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 04-27-2015, 02:10 PM   #5
jdlimages's Avatar
1961 22' Flying Cloud
Oklahoma City , Oklahoma
You absolutely MUST do a search for LED lighting on Ebay. LED strips that cost $60-85 each at Best Buy are $16-20 in Ebay. There are tons of sellers plus the ac adapters and controllers are way cheap too.
jdlimages is offline   Reply With Quote
Old 04-27-2015, 02:55 PM   #6
Excella CM's Avatar
1978 31' Excella 500
Venice , California
You can buy 5m rolls of self-adhesive 300 or 600 l.e.d. strips in just about any color for around $20.00. They're 12 volt and simple and ready to use if you can do simple soldering.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 04-27-2015, 03:41 PM   #7
Cardinal283's Avatar
Dallas , Texas
Excella, do you know where you saw them at that price?
Cardinal283 is offline   Reply With Quote
Old 04-27-2015, 07:58 PM   #8
1967 26' Overlander
Spartanburg , South Carolina
Converted my 47 yr old fluorescent fixture to 12v LED using 2 12" strips from a motorcycle running light kit I bought at Auto Zone for about $12.
Jacob D is offline   Reply With Quote
Old 04-27-2015, 08:28 PM   #9
aquinob's Avatar
Portsmouth , Virginia
Leds are cheap, but I would look on amazon rather than deal with ebay sellers. 3 meter rolls are available for around 10-12 bucks and lots are free shipping with prime. You can cut them about every 4 inches where they are designed to be cut. All are 12v so you dont need any ac adapters. They come with a self stick backing so fairly easy to put where you want them. Generally you need to solder small wires to the ends but with a bit of practice its not too hard.
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 04-27-2015, 08:37 PM   #10
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I bought this;
Hi! I found this on eBay and thought you might like it! Check it out now: 5M 500CM RGB 5050 300LED SMD Ultra Bright Flexible Strip Lights IP6 DC 12V | eBay
You then clean off the adhesive and plastic then you solder wires. Easy..
Now, to control brightness, you get an LED driver/dimmer. Wirks great!!!!
Peace and Blessings..
Channing
WBCCI# 30676
Over-cabinet LED strip lights...YAY! vinnysca Lights - Interior & Exterior 9 01-26-2012 05:01 PM
LED strip lights / tracks build Darkspeed Lights - Interior & Exterior 0 10-19-2011 10:16 AM
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 11:03 AM
To strip or not to strip. That is the question. mjmcwhorte Cabinets, Counter Tops & Furnishings 2 01-16-2006 08:10 AM
