Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 05-29-2008, 11:40 AM   #1
Lothlorian
Profile:  1973 27' Overlander
Loganville , Georgia
Advice needed wiring Peterson tail light
I went to Northern tool today and bought peterson round break and tail lights. I shaved the sides a hair and they fit in perfectly. I was able to wire the red break and turnsignal light and it works fine. I am having trouble wiring the clear tail light. The airstream only has one red wire for the light which you can see to the far left. It has a clip on it. . The connector to the light has three wires. A red, black and white. Does anybody know the sequence for wiring this light. Please check out the pictures below. Click on the pictures to zoom in.
SIU Bound
Brian
ID:	61238   Click image for larger version
Lothlorian is online now   Reply With Quote
Old 05-29-2008, 12:01 PM   #2
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Brian,
Get a 12VDC battery and do a little test of the light. Red is usually (+) unless the wires are black and white, where the black becomes (+) and the white (-).
The presence of 3 wires on a tail light usually mean a second function, like running and turn of a hi/lo pattern. Try either the white or black as the ground and the other as hot. Start with the red on the (+) terminal.
Try touching the wires to the battery to figure out what functions they operate in the light.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
lewster is online now   Reply With Quote
Old 05-29-2008, 01:17 PM   #3
HowieE
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
Get a volt meter or a simple 12 volt test light. Ground one side of the meter/tester to the trailer body at the light socket.
Connect the trailer to your TV. Turn on the parking lights and test each wire till you have voltage. That is the parking light circuit and goes to the smaller filament in the light fixture. Hold for a min. as to how to determine which one that is in the fixture. Now turn on the directional signal and again test for voltage while the turn signal is flashing. That is the brake/turn signal line. Now with the key on put the TV in reverse and check for voltage. That is the backup light and is the clear one.
Now take the light fixture to your truck battery and while someone holds the fixture, the metal case, to the ground post on the battery connect one at a time the 3 wires on the fixture to the battery positive post. As you do this note which bulb light with each wire. The brake light will be very bright, the parking light will be in the same red lens but not as bright and the back up light will light the clear lens.
Now you have define each function on both the trailer and the light and can mke the connections.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
HowieE is online now   Reply With Quote
Old 05-29-2008, 01:28 PM   #4
Chuck
Sad Moderator
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
first, you have to tell us what the model # for those BRAKE/tail lights are....
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 05-30-2008, 05:27 AM   #5
Lothlorian
I am posting pictures of the light that I bought. Howie that is one cool looking mail box.
I fooled with the lights until I was blue in the face. I am getting electricity coming through the wire. I hooked the light up to a 12v and it worked fine. The tail light I removed was working fine but it was the only one of the lights that was working and was not rusted with holes. At least I have break and turnsignal lights,
SIU Bound
Brian
Name:	three plug wire.jpg
Old 05-30-2008, 01:38 PM   #6
HowieE
HowieE's Avatar
Images: 11
PM me a phone number and I will call you and lets figure this out.
Old 05-31-2008, 12:07 PM   #7
HowieE
HowieE's Avatar
Images: 11
This picture is of the 7 pin connector at the end of the trailer cord while looking at it face on. To test the truck wiring pins will be reversed left to right Power will be at 1 o’clock and Parking lights at 11 o’clock.
I could not find a diagram for your original trailer wiring. However if you have a voltmeter you can locate the trailer battery and work from there. Ground out one side of the meter and then test each pin on the trailer connector till you see 12 volts. Once you have 12 volts you have found the trailer battery and trailer ground. Make a lead with a 10 amp fuse in it and use this lead to test from the 12 volt pin to the other pins. I suggest a 10 amp fuse just to be on the safe side.
Take notes as you touch the lead from 12 volts to each pin on the trailer. 2 of them will blow the fuse, ground and brakes, and this is intentional for now. Continue testing each pin till you see the marker lights. Once you have found the marker lights and while the lead was still o that pin, go to the rear of the trailer and test with the volt meter for the wire with 12 volts at the light fixture. That is your parking light circuit and you should see it on each side of the trailer. By now you should have identified power, parking lights and 2 wires that blew the fuse. Now connect to one of the remaining pins and go to the rear of the trailer and test for voltage. You should only find it on one side. That is one turn signal. Do this again on another pin. You may see the other turn signal or nothing. This is because there is a pin in the 7 pin connector that is an aux or back up lights and that may not be used. If you did not find the other turn signal try the last pin. If you found 2 circuits that tested 12 volts on both sides of the trailer yo have a backup light system also. You can distinguse bteween the back up and parking lights because only one will also have the marker lights on when powered.
Now for the ground and brake identification. Jack up one wheel and while someone is spinning that wheel just TOUCH a wire between power and one of the remaining pins, you will see an arc, If you have touched the brakes the wheel will slam to a stop. If the wheel did not stop that is the ground pin. Do not hold the wire on the pin because if it is ground you will be drawing full current.
You should now have each circuit identified on the truck and trailer. If the pins on the trailer do not match those on the umbilical you will have to rewire one end of the umbilical to make the transition inside the cord connecting the wires circuit to circuit
Old 05-31-2008, 02:56 PM   #8
Excella CM
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
That should be simple. Ground the fixture black wire to the trailer body and connect the red wires together.
"Not all who are lost are wondering" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 05-31-2008, 03:09 PM   #9
HowieE
HowieE's Avatar
Images: 11
Would you care to elaborate a bit on what Black wire and which 2 Red wires you are refering to.
It appears he may have a wiring problem, new 7 pin plug to the older trailer plug, at the front of the trailer that has to be resolved first.
Tail light wiring? LI Pets Electrical - Systems, Generators, Batteries & Solar 5 10-17-2006 09:12 AM
Tail Light Wiring sshadow Electrical - Systems, Generators, Batteries & Solar 4 10-31-2003 11:17 AM
Tail light assembly needed. AccessMaster Airstream Motorhome Forums 6 08-05-2003 08:35 AM
Broken wiring in tail lights Argosy74 Electrical - Systems, Generators, Batteries & Solar 4 10-23-2002 10:09 PM
Bargman #99 wedding cake Tail light needed cindy Lights - Interior & Exterior 8 10-16-2002 09:52 AM
