Old 09-18-2007, 07:58 PM   #1
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Adding Exterior Outlet
On our model Airstream chose to put the outside outlet inside the curbside access door. It's a pain so I went looking for a way to add an outlet on the skin. Couldn't find a stainless exterior outlet anywhere - so one day while passing a truck I noticed the cover they have for hooking up an engine heater line.
The cover came from a truck repair shop - the outlet is a 20 amp extension cord replacement end from Lowes. The little Airstream was added to dress it up a bit. It will be added next to the access door and wired to the existing "exterior outlet"
ID:	45639   Click image for larger version
Old 09-18-2007, 08:52 PM   #2
2005 22' Interstate
Afton , Virginia
I'm a little confused. The yellow plug looks like it is "female" and would accept "male" gender plugs. If that's so and if there is a "male" plug behind the plate, then is this outlet live when using shore power? If so, that is a hazardous situation. I wouldn't do it.
herrgirdner is offline   Reply With Quote
Old 09-18-2007, 08:55 PM   #3
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Now I suppose you won't want the chrome double outlet cover I have.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 09-18-2007, 09:11 PM   #4
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
The only plug is the female end it's just shown apart for clarity the other end is bare wire to be connected to the outlet box.
Neil - you remembered - how funny. No I'm good now and this effort is all your fault :-)
Old 09-18-2007, 09:27 PM   #5
FreshAir's Avatar
1966 24' Tradewind
No, I did not forget. I wanted to help you but as time passed I realized how difficult it would be to locate what I wanted. I did find a single outlet cover but it isn't shiny so I thought I had better hang onto my shiny one too. However, your find gives me an avenue to pursue. The 'little Airstream' is a nice touch.
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
Adding a 12VDC outlet outside?? myoung Electrical - Systems, Generators, Batteries & Solar 6 08-25-2006 05:42 PM
Exterior electrical outlet cover airstream4 Exterior Restoration Forum 1 12-05-2004 01:37 PM
Should I? (adding exterior lights) bredlo Lights - Interior & Exterior 20 03-12-2004 06:48 AM
Help!! exterior outlet cover stuck TheBigRedTruck Electrical - Systems, Generators, Batteries & Solar 8 06-28-2002 11:04 AM
Exterior 120 volt outlet cover thenewkid64 Electrical - Systems, Generators, Batteries & Solar 8 06-16-2002 08:54 AM
