i finished adding the light above the door
i could not pull a wire as there was a vertical beam in the wall between the door and the inside light switch
i drilled a hole inside under the light cap and then a small one inside and lower under the head bumper cushion. by removing the metal strip, i was able to hide to 22 Ga 12 v Dc wires behind the cushion and behind the metal strip
i then pulled the wire 9 " to the light switch
now the over head door light goes one when we turn the foot light on.
it took about a day to do, assuming you have all the tools and bits
