Old 02-20-2014, 10:28 AM   #1
Muskie's Avatar
1959 24' Tradewind
collingwood , Ontario
AC inlet mystery for a '59 Tradewind
Hi folks, I am doing some wiring and want to keep this employed as it looks in good condition, and to buy new one is expensive. Curious if there are any adapters that are up to date with todays 30amp plugs? Any other suggestions on how to make it work are welcome.
Cheers
Muskie
Name:	ac adapter.jpg
Those that think they know don't know, those that know they don't know, know.
Muskie is offline   Reply With Quote
Old 02-20-2014, 10:36 AM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
Mating connectors haven't been manufactured for years. Occasionally someone has one to sell if they've purchased a trailer that came with a matching cord and they are upgrading to a Marinco style connector.
Old 02-20-2014, 10:40 AM   #3
Muskie's Avatar
1959 24' Tradewind
Thanks, Jammer
What would I call such a thing, 'vintage mating connector 30 amp?'
-m
Old 02-20-2014, 10:44 AM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I cannot find any NEMA plug/socket that uses three straight pins in that configuration. If you can find a NEMA number on either the socket or plug, that would help immensely.
A NEMA 10-30 uses two straight pins and an L-shaped one, but that's the closest I've found.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 02-20-2014, 10:56 AM   #5
Muskie's Avatar
1959 24' Tradewind
120V-35A
Heavy duty connector
and what looks like 30 Q-3?
Theo Bargman
cheers
Old 02-20-2014, 11:04 AM   #6
Cyquest's Avatar
1969 23' Safari
Blenheim , Ontario
Couldn't you take it apart and replace with a newer? Swap guts?
Sent from my LG-E617G using Airstream Forums mobile app
Cyquest is offline   Reply With Quote
Old 02-20-2014, 11:05 AM   #7
Originally Posted by Muskie View Post
120V-35A
Theo Bargman
cheers
That gets me closer. I was looking at just 120v and 30a. Seeing the 35a rating prompted me to broaden my search.
The NEMA 11-series is designed for 250v applications, not 120v, but has similar pins. Don't know if the NEMA 11-30 or NEMA 11-50 pins are the same size as yours, but if you order one from an electrical supply house that has a decent return policy, you could always try it and return it if it doesn't fit.
WBCCI #1105
TAC LA-4
Old 02-20-2014, 11:16 AM   #8
Muskie's Avatar
1959 24' Tradewind
Thanks folks
I will try an electrical supply, and barring that I will try and drill out the guts as it is all one unit, and replace the inside with a standard house plug [somehow!?]
'66 Tradewind Mystery Component dbj216 Electrical - Systems, Generators, Batteries & Solar 8 01-06-2014 07:32 AM
City Water inlet AYRSTRM2 Fresh Water Systems 5 06-08-2004 06:57 PM
Water inlet key replacement Road Ruler Fresh Water Systems 7 09-03-2002 09:07 PM
Black Water inlet flange Dave Shanahan Waste Systems, Tanks & Totes 1 08-18-2002 03:09 PM
city water inlet valve failure? JohnGalt48 Fresh Water Systems 2 08-01-2002 04:43 PM
