When I was last at the factory in December I picked up an 18 inch florescent light assembly to place over my sink and prep space. This replaced my 12 inch assembly. What to do with the "old" 12 inch light assembly? Well I held on to it until I figured out what it would be used for. I spent much of the winter in and out of the trailer staying with friends and family. I finally settled down in Boise for the summer. Which means I started using the shower stall regularly. Meaning I had to shave my legs. After a couple of time of doing this I realized I was missing spots. regularly. I did not have enough light to see what I was doing. So the extra 12 florescent lamp was installed in the shower stall this afternoon. Three times the light output of the old fixture. The only issue is the unit in the shower cannot be switched. Some code thing. Thanks Randy at the Factory. No problem I just bypassed it. This evening when I shower I will find out how well it works.
Picture one is the new fixture in the kitchen and two is the fixture in the shower.
Michelle
I'm not afraid I learned to drive in Washington, DC
Sarah
Ruby, (05 BMW R1200RT) serviced and put to bed for the winter
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Classic 31 w/dinette, solar) http://Michelles-Adventures.US
Well I finished my shower a few minutes ago and I LIKE IT! The fixtrue has a larger foot print but not as think. I finally was able to shave my legs and not miss anything! Yeah.
Next the closet when I stop by the factory in December.
Michelle
Sarah
Not that I'm particularly worried about switching a 12 volt light in the shower, but if I was...
There is the simple expedient of using a relay and a magnetic reed type switch like on burglar alarms. Put the switch on the back side of the shower wall and use a magnet to turn the light on and off.
"Not all who are lost are wondering" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Well, even if you had miswired it, you still would have had your leg hairs removed ...... by electrolysis. The fact that you used your razor proves to us your wiring was up to code. Neet idea well executed.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Charter Associate Member FCU
Airstream Life "Old Aluminum Adventures"
Great way to reuse a good piece. I was thinking I'd like to put a light in my back storage compartment for those late night set-up events. It might be a good place to put my old fluorescent light to work. Thanks for causing the brain to kick back in Michelle. Donna will think I'm a genius. Well, ok, she will realize I've read it somewhere............
Please forgive my seeming to be dense.... but aren't lights in the storage areas pretty standard??? Guess I never really thought about it. And I guess that my PO was quite innovative, and BUSY!!! I have lights in all read storage areas, incandesents.... might consider getting those to LED's as well.
There have been a time or 20 when I inadvertantly left them on for quite a time....
Virtually EVERY time I read about others units on this site, I am yet again relieved and happy that my SilverToy had a very attentive PO.... so many great ideas that are already in place. Isn't there a saying - Sometimes it is better to be lucky, than good.
Greetings Michelle- Randy can do almost anything, a real asset to AS, JC. When you mention couldn't be switched, do you mean have a switch onside the shower? Isn't it wired to a switch outside the shower? If not you could easily have that taken care of.
Rick
__________________ J. Rick Cipot Sandi Gould NEUNew England Unit Airstream Life Magazine WBCCI #3411 AIR #17099
The fixture in the shower stall cannot be switched. Something about corroding contacts. There is a light switch outside the stall that controls stall and sink/toilet area.
Michelle
Sarah
Just lucky I guess! Yipee!
Ciao
Axel
SilverToy
Axel
My 1951 Flying Cloud did not come with very much when I acquired it. It was basically used as a park model and primarily for sleeping only, so there was not much in the way of conveniences. Adding the basics was the first priority (toilet, tanks, flooring, decent beds, cupboards and doors etc.) so now I'm into the neat stuff like lights in the dark areas. Not that there is a lot of places this is needed, but there are a few areas. I'm thinking I may use a small clip on light with it's own battery.
Well I find that strange since our Safari has a wet bath and we have a switched light. Oh well. So you have to turn it on and off with the switch on the light unit? Isn't that a little scarry when your hand are wet?
