Old 07-01-2010, 03:52 PM   #1
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
A few lights now are out
My last trip in the trailer was two weeks ago, everything worked well. For some reason now my two bedroom reading lights and the bathroom overhead vent light are not working. All other lights and electrical outlets are fine.
Could these few things be on one fuse? I checked but did not see a burnt fuse, however I need to get a flashlight and really look more closely.
Any ideas?
Old 07-01-2010, 04:54 PM   #2
richinny's Avatar
2011 34' Classic
sometimes the fuse contacts get corroded or the fuse has a tiny break. get a meter or test light out and test both sides of the fuses.
Ricky
Old 07-01-2010, 07:17 PM   #3
1978 28' Ambassador
Savannah , Georgia
Since I did not disconnect battery when attempting to install the univolt. now have to question everything. To test the fuse, do you have to pull it out of the fuse box to test it? Thanks. Jack
Skamper1 is offline   Reply With Quote
Old 07-01-2010, 08:25 PM   #4
richinny's Avatar
2011 34' Classic
questions are good :-) no, with glass fuses you just touch the metal ends. with plastic blade fuses, look for a tiny dot of exposed metal on the top ends and test it there. going to one of the non working lights and testing there will tell you if there is power in the line. if a fuse is blown, you have a 'short'. if the fuse is good and no power to the lights, you have an 'open'. don't forget to verify that the ground that feeds these items is good.
Ricky
Old 07-03-2010, 07:57 PM   #5
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Will do , the meter is sure a well used item in my toolbox.
Old 10-05-2010, 07:51 PM   #6
1978 29' Ambassador
me , Texas
AlanSD,
could you update on what/how you found, (i think i'm having a similar problem -In my kitchen, overhead light is not working along with the lights over the sink, the exterior step and flood lights and one of the reading lights over the front couch ('78 Amabssador 29'),
THX
qratio is offline   Reply With Quote
No running lights or tail lights... goswick Lights - Interior & Exterior 24 02-27-2010 09:31 AM
Tail lights, brake lights, turn signals on '75 22' mendosoft All Argosy Trailers 3 06-01-2008 08:46 PM
Running Lights/Backup Lights 85 Sovereign GRAYMAN Lights - Interior & Exterior 7 08-10-2004 08:54 AM
Upper Identification Lights aka(Clearance Lights) pap Lights - Interior & Exterior 7 04-08-2003 06:14 PM
looking for brake lights and back up lights larrylisa Lights - Interior & Exterior 6 12-07-2002 06:43 PM
