Old 07-24-2014, 07:38 AM   #1
Gilmurr's Avatar
1998 30' Excella 1000
Halifax , Nova Scotia
'98 Excella light switch question
On our '98 Excella, just inside the door are switches for lights. 1st is the step light, second is the lounge overhead light in the fan, and the third is labeled "ceiling", but does nothing. I would assume it would turn on the galley cieling lights. Has anyone have any sugustions on what the third switch is susposed to do and repair? see attached photos, front and back of switch plate
ID:	217278   Click image for larger version
David & Andrea
'98 Excella 1000 Classic 30ft
2007 Toyota Tundra Dbl Cab
Gilmurr is offline   Reply With Quote
Old 07-24-2014, 08:11 AM   #2
Livingston , Texas
I have the exact same rig. Mine only has the two switches that control the features you mentioned. Must have been an added option on your rig, but what it controls...?
Siegmann is offline   Reply With Quote
Old 07-24-2014, 10:21 AM   #3
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
I have a '97 and it does in fact turn on the galley light in front of the a/c.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 07-25-2014, 11:03 AM   #4
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Our '95 30' has the same panel but with a fourth unmarked switch.
The second switch turns on the light over the couch. The third switch turns on the light over the kitchen area. The fourth switch wasn't wired to anything; I suspect it was used for the optional valance lighting that ours doesn't have. (I wired it to turn on our parking lights.)
Break out the multimeter and confirm you have power on both sides of the switch when it's on. If so, head to the light and see what's up there power-wise. If there's no power coming into the light then you probably have an issue with your wiring harness.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 07-25-2014, 11:15 AM   #5
Gilmurr's Avatar
The lights in the kitchen area (2) both work with the on/off switches in each...but the switch at the door has no effect. Will have my meter next time out and will check power at the switch and try to chase the wires down.
David & Andrea
Old 07-25-2014, 11:17 AM   #6
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Oh, I misunderstood. Our overhead lights do not have switches on them; the only control is the one by the door.
Overhead Light Switch "HI-LIGHT-LO" motilley Lights - Interior & Exterior 14 08-23-2017 06:11 AM
need hi-lo light switch for 1981 Excella II ole81 General Interior Topics 1 08-26-2013 09:20 PM
3-way galley light switch question Skamper1 Lights - Interior & Exterior 9 11-28-2010 01:53 PM
Light Switch (Wall Switch) for 69 Overlander mbmbstreamer Lights - Interior & Exterior 3 03-21-2010 04:39 PM
Plastic light switch for ceiling light in 1979 Sov. Bowmans Lights - Interior & Exterior 4 10-14-2009 05:17 PM
