Old 04-30-2008, 05:38 AM   #1
AxelBruijnis's Avatar
1978 31' Sovereign
Gasselternijveen , drenthe
Send a message via AIM to AxelBruijnis
'86 Excella Taillight replacement problem
i recently purchased new taillight bezels for my 1986 32 ft excella .
when i tried to order them , i got this response :
"I checked with Airstream and was advised the original bezel are NLA but they have a replacement bezel that retails for $66.11. ea."
i did order them, and left them unused for few months,
Yesterday , i started to install them, and i discovered that they are much larger then the older versions.
the new model doesn't fit in between the lines .
does anyone know a source for the proper size ?
( preferably the original color as well )
thank you for responding !
Axel Bruijnis
ID:	59449   Click image for larger version
1978 Sovereign 31 Mid Bath
1969 Overlander 27
2000 dodge 2500 diesel
AxelBruijnis is offline   Reply With Quote
Old 04-30-2008, 03:26 PM   #2
1978 31' Sovereign
i guess i will try to reinstall the old damaged bezels for now.
i don;t want to modify the trailer , since i still hope to find better fitting versions.
would a salvage yard sell them ? ( where should i look ?)
or is ebay my best chance ?
thanks,
Axel
1969 Overlander 27
Old 04-30-2008, 04:44 PM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Give Inland Andy an email. He may have some to fit your trailer, or know where to get them. Other sources would be Ebay, Airstream dealers that have been around a while (New Old Stock), or salvage yards for used ones.
Old 04-30-2008, 04:51 PM   #4
thanks,
Axel
Unfortunately, what you received is all that Airstream has.
Looking for a salvaged unit might be a choice, for you.
I have no idea where you might find them.
Old 05-01-2008, 02:08 AM   #5
1978 31' Sovereign
thank you andy !
Axel
1969 Overlander 27
Old 05-01-2008, 03:06 AM   #6
1978 31' Sovereign
thank you, will do so
Axel
1969 Overlander 27
Old 05-01-2008, 08:03 AM   #7
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Axel,
How about these at Out-Of-Doors-Mart...
Airstream Tail Light SKU9503 - $149.95 : ODMRV , Out-of-Doors Mart
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 05-01-2008, 03:10 PM   #8
1978 31' Sovereign
Originally Posted by DEITZ645
Axel,
dear Carl,
They look the same as the oversized ones i already have, but they include the lenses and the rest, i will get in touch with them , and see if they can measure them for me..
In case they are the same, did anyone successfully install the oversized new bezels yet ? any pictures to share please ?
Thank you,
Axel
1969 Overlander 27
Old 05-01-2008, 03:15 PM   #9
DEITZ645's Avatar
Axel,
They have been very accomodating with me. I usually speak with a gentleman by the name of Dan.
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 05-01-2008, 03:17 PM   #10
HowieE's Avatar
Princeton , New Jersey
Images: 12
What is the damage to the originals? Is the web nissing between each lens or is one of them bent?
If it just the web and mounting holes I would consider repairing them by installing a fiberglass matting from behind and using that for the screw mounting. As long as the exposed rim is good you can save them.
2004 Excursion 4x4
Old 05-01-2008, 03:23 PM   #11
1978 31' Sovereign
Hi HowieE,
The mounting screws have been tightened to much in most corners, so most of the holes are twice the size of the screw and two of the in-between pieces are missing, they fell out while taking off the old lenses , before i noticed the difference in size.
They looked like they were ready for replacement, and it seemed like an easy cosmetic repair ( before i started , that was)
Axel
1969 Overlander 27
Old 05-01-2008, 05:57 PM   #12
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Wow, am I glad I read this post! I am in the midst of redoing the outside of my '86 Sovereign & just assumed I'd be replacing the taillight bezels. I've had such good luck with replacement parts through Airstream on this model, that I figured these would be there too! I guess I'll baby the ones I have & put them away for safekeeping until I'm done with my project! Thanks!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 05-01-2008, 06:40 PM   #13
HowieE's Avatar
Images: 12
Axel
As long as the basic frame is straight repair them. If you are not familiar with working with fiberglass try and find someone that repairs boats or builds kayaks. They will be able to show you how to repair your frames.
If you do repair them I would suggest glassing in small pices of metal behind each of the screw holes as new material to screw into.
You might take a look at what I did while upgrading my tail lights. See post 40, 49, and 51 on this thread.
http://www.airforums.com/forums/f311...hts-23544.html
2004 Excursion 4x4
2008 Classic Taillight Replacement CharlieSK Electrical - Systems, Generators, Batteries & Solar 4 10-10-2014 11:57 AM
Rear LED Taillight Problem - 2008 Classic 25fb KJRitchie Lights - Interior & Exterior 4 11-13-2013 06:53 AM
'65 Safari Taillight Replacement Help rburditt Lights - Interior & Exterior 19 11-04-2012 08:05 PM
'74 Sovereign taillight and backup light replacement texasbound Lights - Interior & Exterior 2 10-07-2012 09:47 PM
LED replacement for '64 Auto-Lamp 7" taillight Globie64 Lights - Interior & Exterior 8 03-12-2011 07:37 PM
