Old 10-31-2010, 09:49 PM   #1
1984 31' Airstream310
perth , west australia
'84 310 motorhome 12 volt distribution panel wiring diagram
can anyone please help. i need to find out what the d circuit or also known as circuit 4 with the brown wire powers as this fuse continually blows when replaced. the a/c light on the main control panel also stays on when batteries conected. can this be related?
d circuit is 4th fuse down from the top in the 12 volt distribution panel.
thankyou .
mick32 is offline   Reply With Quote
Old 10-31-2010, 11:03 PM   #2
Santa Cruz , California
Images: 12
Circuit 4/D/brown
If it's the same as a 1983, this circuit powers the map light/compartment lights/walkway lights (switches at the left side of the dashboard), and something in the monitor panel. Has the wiring in the monitor panel been disturbed? The AC generator light on the panel is supposed to be powered from the purple wire, which is fed from the ignition relay in the AC generator set.
dljosephson is offline   Reply With Quote
Old 11-01-2010, 01:06 AM   #3
circuit 4/d brown.
thankyou for a speedy response. that gives me something to work with and points me in the right direction. do you know where i may be able to obtain a wiring diagram for the 12 volt distribution panel.
thankyou again.
Old 11-01-2010, 11:16 PM   #4
Images: 12
You really should get the whole manual, it is available for about $30 from Airstream. Most of the electrical system is there and a clear picture of the fuse panel.
12 volt
12 volt panel location-'79 24' motorhome roadking67 Electrical - Systems, Generators, Batteries & Solar 1 10-05-2011 10:48 AM
12 volt panel location kmoore Electrical - Systems, Generators, Batteries & Solar 5 08-24-2011 09:45 PM
67 Ambassador Wiring Diagram brownv1 Batteries, Univolts, Converters & Inverters 4 06-30-2011 10:06 AM
Does anyone have a wiring diagram for a '68 safari?...Please HolyRoller Batteries, Univolts, Converters & Inverters 1 05-11-2011 09:45 AM
Power Steering Not Working - 310 Motorhome steveturk Classic Motorhomes 27 02-18-2011 05:00 PM
