Old 09-11-2011, 08:12 PM   #1
1981 31' Excella II
New Market , Alabama
'81 Excella II Fluorescents Not Working
Some of my Flourescent Lights are not working on my 81 Excella II. I suspect the ballast is dead. Does anyone make replacements for these things?
Perry
Old 09-11-2011, 08:36 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
ThinLite makes replacements. If you are the original purchaser of the fixture, and have your receipt, there is a lifetime warranty on them. If not, they are about 1/2 to 2/3 the cost of a new fixture. At that point, I would be considering LED strips to replace the tubes.
Old 09-11-2011, 08:40 PM   #3
1981 31' Excella II
Well how much is a ballast in real terms not relative terms. You can't just go to Lowe's and get a 12 V powered ballast or light fixture. LED's are a little too white for me. I just want to get them working at this point.
Perry
Old 09-11-2011, 08:45 PM   #4
Well Preserved
1993 21' Sovereign
Perry
They are $18-$25 each, plus shipping, depending on model and who you get them from.
Old 09-11-2011, 11:16 PM   #5
Dan@LED4RV's Avatar
Denton , North Carolina
same color
.........LED's are a little too white for me. .............Perry
Perry,
The warm white are so close to the light you have in there, you almost can't tell it.
T250mmWW
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 09-12-2011, 06:37 PM   #6
1981 31' Excella II
Dan what you got that is LED that would be good for area lighting and not spot lighting?
Perry
Old 09-13-2011, 12:20 AM   #7
Dan@LED4RV's Avatar
Yes Area lighting
Perry
Yes the LED strips are good for area lighting. We designed them for the 12 volt fluorescent lights. They work good and if your fluorescent lights are over two years old the LED strips will put out more light. They fit in the light housing and by-pass the ballast.
Dan Brown
Denton NC
Old 09-13-2011, 05:38 AM   #8
1981 31' Excella II
Ok is was wanting to keep the stock look anyhow at least for now. The OEM diffusers will make the light from the LED's a lot less harsh. I have three roof vents on my trailer. Are all of them supposed to have lights in them? I think most of mine are working accept the two over the rear beds.
Perry
Old 10-14-2011, 08:59 PM   #9
1981 31' Excella II
All my lights work after replacing some blown fuses. So check there first eventhough getting behind the coucho is a pain.
Perry
What makes an Excella an Excella? MaraLindstro 1990 - 1993 Excella 16 07-08-2012 11:05 PM
Hot Water not working, 1991 Excella 1000 34' jbbaldwin Water Heaters, Filters & Pumps 8 06-01-2011 10:50 PM
Excella Info? M Williams 1981 - 1983 Excella 4 01-26-2011 07:13 PM
