Old 11-12-2006, 07:24 PM   #1
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
80's tailight gasket?
I found a rear tailight lens cracked at one corner of my '86 Sovereign probably because I tightened the screw a little tighter than I should have when I replaced a blown bulb. I ordered several new lens and am ready to replace two now and maybe two later on. I've noticed that there is some "crud" on the inside of most of the lens and found that none had any type of gasket around the edge of the lens. OK, should there be a gasket and what type of material should it be? Thanks in advance.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 11-12-2006, 08:44 PM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
craig
these are the square ones made by monarch?
john
you call them ferrets, i call them weasels.
Old 11-15-2006, 08:27 PM   #3
davidz71's Avatar
1986 25' Sovereign
Originally Posted by john hd
craig
john
Yes John, I believe you are correct.
Craig
AIR #0078
3.73 rear end
Old 11-16-2006, 03:55 AM   #4
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Have you checked here?
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 11-16-2006, 04:13 AM   #5
peegreen's Avatar
1998 31' Excella 1000
South Berwick , Maine
There is a rubber gasket that goes behind the inner can with very little rubber exposed to the plastic lens. Not yery effective. One of mine gets water behind it crud builds up on the back of the lens.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 11-16-2006, 06:23 AM   #6
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
yes that is why i asked what type they were. mine are the same way from the factory.
i think they are basicly gasketless to allow condensation to escape.
i remove mine yearly and soak in the sink with dawn dishwashing soap to clean them up.
it is amazing how much crud gets in there.
john
Old 11-16-2006, 10:05 AM   #7
peegreen's Avatar
I do the same. I replaced mine because the red lense appeared to darken with age. I put some aluminum foil behind the bulb to add reflectivity(?). While traveling at night this past weekend, the tailights appeared very bright and looked good. I'm in no hurry to make modifications to LED's.
WBCCI 24291
New England Unit
Old 01-18-2007, 09:13 PM   #8
davidz71's Avatar
1986 25' Sovereign
john
I lost this thread somehow but this weekend I will replace the 2 worst looking offenders, the one with broken corner and the dullest one of the bunch after cleaning. I also picked up one tip in the last year about putting a small o ring on the screw holding the lens in. While you would have to replace them from time to time, the idea that they are snugged up and there is some give might prevent another one from cracking.
balgrn, Vintage Trailer Supply was exactly where I bought the lens. I didn't even think about asking if gaskets came with them.
Craig
AIR #0078
3.73 rear end
Late '80s Airstream Aluminum Fifth-wheel acwdgw Integrity 5th Wheel (all Years) 17 01-09-2004 10:20 PM
Exhaust ALANSD Airstream Motorhome Forums 44 11-30-2003 09:23 AM
Stupid Human Tricks airstreamcaravel General Repair Forum 12 11-20-2002 02:08 PM
1980's Airstreams davidz71 Our Community 19 11-06-2002 11:17 AM
Source for window gasket jaiman Windows & Screens 2 09-07-2002 09:16 PM
