Old 04-24-2011, 07:35 PM   #1
1974 29' Ambassador
1976 25' Caravanner
trenton , Missouri
'76 caravanner exterior lights
thr owners manual shows four wires coming through the roof to the tail light assembly. White, ground red,left turn and stop brown, right turn and stop green, clearance. My trailer has green, white, red, brown with white stripe, and brown with green stripe. What are these two brown wires with stripes?
bimpy is offline   Reply With Quote
Old 04-24-2011, 07:50 PM   #2
Probably for the back up lights.
Old 04-24-2011, 09:34 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Green = Tail/Marker Lights
White = common/ground
Red = Left turn
One of the browns is the right turn; I would guess it is the one with the white strip.
The other is probably back up lights if you have them.
You could test it out with a battery charger. If you have a 7 way plug, the center pin will more than likely be the backup lights.
Old 04-24-2011, 09:40 PM   #4
1974 29' Ambassador
1976 25' Caravanner
trenton , Missouri
Thanks fellows, I forgot to mention the manual shows black for the backup. I can't seem to get anything from the green striped with a test light will try again tomorrow.
Caravanner :: 1957 Airstream Caravanner floyds Airstream Registry Discussions 0 08-19-2011 08:32 AM
'57 Caravanner Island Girl :: 1957 Airstream Caravanner pbearsailor Airstream Registry Discussions 0 08-19-2011 08:30 AM
1971 Caravanner Outside Outlet Max Well Lights - Interior & Exterior 2 08-14-2011 06:09 PM
Univolt on a 1976 Caravanner wba1 Batteries, Univolts, Converters & Inverters 12 07-27-2011 07:13 PM
New owner of 1956 Caravanner WKBeaudet Member Introductions 5 07-07-2011 10:17 AM
