Old 01-25-2016, 12:08 PM   #1
1975 31' Sovereign
Gilbert , Arizona
'75 Sovereign, wanting to go all LED outside
I want to go all LED wherever possible and was planning to start with the exterior - everything: clearance, brakes, running lights, porch, scare, whatever. The first round was the clearance lights due to relative low cost and ease of replacement. That was until I realized I have a single hot wire from the trailer to each fixture and the lights require polarity <facepalm>.
So clearly it's not going to be as simple as I'd like it. What are the issues?
Wiring is all original.
Yarginator is offline   Reply With Quote
Old 01-28-2016, 09:31 AM   #2
1968 28' Ambassador
Southwest Ranches , Florida
Unfortunately I am in the same boat! Wish I could help, but at least this will bump the thread to the top! I'm actually having trouble with the tail lights and backup lights (the small ones near the bumper) and finding LED replacements for them - or doing the LED's myself on incandescent lights.
Let me know if you find any info about your predicament!
I'll post on here if I find something related.
Nick
mashburn.nick is offline   Reply With Quote
Old 01-28-2016, 10:30 AM   #3
2005 19' Safari
GLENDALE , AZ
Our 19' Bambi is newer; but three years ago, we replaced all INTERIOR incandescent bulbs with the LEDs listed in the link, below.
http://www.airforums.com/forums/f447...ml#post1541211
Note: These LEDs are direct replacements for incandescent bulbs. However, they will NOT work with fixtures that have two hot leads (e.g., running light AND brake light in same bulb), which have two center connectors instead of one. If those are needed, I'm sure the vendor has those, also.
So far, absolutely no LED failures or problems.
sovereign
LED Tow Vehicle to LED Trailer Problems murreywalker Hitches, Couplers & Balls 25 09-10-2012 03:42 PM
To LED or not to LED? SilverHoot Lights - Interior & Exterior 56 10-03-2011 12:15 PM
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 11:03 AM
