Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 05-28-2008, 05:52 PM   #1
Lothlorian's Avatar
Loganville , Georgia
'73 Overlander turn signal light housing
I removed the lights and the housing for my tail light and turn signal lights. They were rusted terribly. One housing has to be rebuilt completely because it is almost disintegrated and the rest of the housings need new sockets installed because of corrosion.. I am pretty sure I can handle that. My question is on the housing where the brake and turn signal lights fit there is a little bulb in the middle of the housing behind the brake light bulb. It is incased in a rubber covering with a black wire attached. What is the bulb for, and can you buy replacements.
On the driver side of the trailer on the side close to the hot water heater their is a light that you can see from your rear view mirror. The light works but the part that covers the wires and lights is missing. What is that light for?
I replaced all the clearance lights today. I bought my replacements from Northern Tool. They had the exact lights. I made my own gaskets and sealed the lights to prevent leaks. They all worked except one. I will worry about that one when I get the tail lights in and my new tires on.
SIU Bound
Brian
Lothlorian is offline   Reply With Quote
Old 05-28-2008, 06:09 PM   #2
Retired.
. , At Large
Those are fiber-optic lenses for your taillight monitor. They do not light by themselves, they merely transmit light from the taillights to the monitor.
Old 05-28-2008, 06:10 PM   #3
Retired.
. , At Large
That is the other end of the taillight monitor.
Inland RV sells the housings.
Old 05-28-2008, 06:27 PM   #4
Lothlorian's Avatar
Overlander 63
Could you explain more to me about the the tailight monitor? I am trying to understand how that works and what it is for
SIU Bound
Brian
Old 05-28-2008, 06:35 PM   #5
Retired.
. , At Large
Fiber optic lines run from the deepest, darkest corners of your taillight housings to the housing near your water heater. They are basically light tubes that can flex. There is a small enlarged area on the end in the housing by the water heater that shows the light that has been transmitted. We have the same on our Sovereign, though the monitor itself is all the way up front by the radio antenna.
Fiber optics seem to work pretty good, our internet connection is via fiber optics.
turn signal light bulb replacement...bulb not turning ArgosyMinuet All Argosy Trailers 5 01-01-2021 10:21 PM
Back turn signal light bulb broke and can not get out ArgosyMinuet All Argosy Trailers 5 04-22-2013 04:36 AM
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 02:01 PM
The External Turn Signal fiberoptic light RichHog Lights - Interior & Exterior 9 11-16-2009 04:31 PM
Brake light / Turn signal issue Miss Vicki Lights - Interior & Exterior 4 05-28-2009 04:51 PM
