Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 06-22-2009, 06:49 PM   #15
PizzaChop's Avatar
Profile:  1973 31' Sovereign
Danielsville , Georgia
Images: 197
Mike,
I pulled both frames and buffed them before replacing cans with "modified" SignalStat (now Trucklite) cans and lenses.
Here are a few pics. A bit more work than the LEDs but you can drill a hole in the back of the can and use the fiber optics as well.
I purchased four lights, 2 clear lenses (for backup), and 12 side marker lights for less than $100 from a local truck supply outlet. (I strongly recommend replacing all lights if you haven't already...I love having everything work when I leave the driveway.)
There's a bit of work involved modifying the fixture, but not too much. It kept the original look, which I prefer.
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old 06-22-2009, 08:31 PM   #16
Profile:  1973 27' Overlander
Loganville , Georgia
Pizza Chop told me what he did last year so I took his advice and did the same thing. I got my replacment lights at Northern Tool. I took the lenses of my airstream down to Northern Tool and matched them with Peterson lights. They work great and very inexpensive. The round lights edges have to be sanded a little bit and then they fit right in.
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 06-22-2009, 09:20 PM   #17
DPeakMD's Avatar
Profile:  1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
Send a message via Yahoo to DPeakMD
I'm not clear on how you guys knew where to drill through the aluminum bezel to remove the rivets.
Dallas
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Old 06-22-2009, 11:09 PM   #18
mello mike's Avatar
Profile:  1972 31' Sovereign
Phoenix , Arizona
Images: 14
Thanks, Dallas, Brian and Ron for your responses.
I decided to work on the right brake light, since that's a priorty over the two reverse lights that are still OOC. I drilled out the two rivets holding the can in and with a slight tug, the can came out. After a quick inspection I determined that the can wasn't too corroded, most of that being on the bottom. Took a wire brush, file, and sand paper and cleaned it up. Then applied two coats of black Rustoleum spray paint. Tomorrow, I'll solder the new socket to the can (picked that up at Pep Boys Auto).
I got lucky with the running lights. One of the previous owners replaced them all with the modern running lights with the tiny two pronged light bulbs (don't know the size).
Today I ordered 2 clear and 2 red lenses from Oasis RV. The old lenses were stained, dull, and scratched in some places. They definately needed replacing.
ID:	82773   Click image for larger version
Sterling - 1972 Sovereign Intl (RB)
Eddie - 2003 Ford Excursion (6.0L PSD)
Prodigy Brake Controller / Equal-i-zer Hitch / Honda EU2000i x2
Airstream Life Contributor
WBCCI 4CU #5661/AIR #5661
My Refurb Blog: UPDATED!!
http://mellomikesairstreams.blogspot.com/
Part wanted: 70s Kitchen Counter Unit
mello mike is offline   Reply With Quote
Old 06-23-2009, 07:54 AM   #19
PizzaChop's Avatar
Images: 197
Dallas,
Mine must have been removed at an earlier date and had rivets holding them in from the outside.
Ron Kaes
Psalm 112
www.paparonnis.com
Old 06-23-2009, 10:31 PM   #20
mello mike's Avatar
Phoenix , Arizona
Images: 14
Fixed the right tail light this evening. Rather than soldier the new socket to the can, I soldered a small wire to the socket and crimped a loop fastener on the other end. To form a ground, the loop was attached to one of the screws (used screws instead of rivets to mount the can). Works great and looks great, except I discovered a small problem with my trailer's lights. Time for another thread....
Old 06-23-2009, 11:27 PM   #21
DPeakMD's Avatar
Franklin , Indiana
Good job on the cans, Mike! It looks like you're on the way to getting those lights fixed. I hope you receive the gaskets with your new lenses.
Just checked out your blog. Very nice. If your bathroom is still out, you can remove the inner skins to get to the backside of the lights if need be.
Dallas
WBCCI/VAC #8481
AIR #9
W9CDC
Old 06-24-2009, 06:58 PM   #22
mello mike's Avatar
Phoenix , Arizona
Images: 14
Got the new lenses today from Oasis RV. All of them come with gaskets and new screws.
Old 06-24-2009, 10:46 PM   #23
mello mike's Avatar
Phoenix , Arizona
Images: 14
Okay, here are some pics of the right tail light fully refurbished. Note the grounding wire for the new socket in the one pic and the new Bargman Lens in the other.
ID:	82913   Click image for larger version
Old 06-25-2009, 12:03 AM   #24
Power to the People !
Maryw164's Avatar
SAN DIMAS , California
Send a message via AIM to Maryw164 Send a message via Skype™ to Maryw164
Mike,
It's probably too late, as you have already installed the new lights/lenses; but if you paint the inside surface behind your light bulb (can?)silver it will reflect the light better and help make it brighter. Just an idea.
Mary
Happy Trailering !
Forums member #29232
Check out my new Blogs (work in progress):
http://www.airforums.com/forums/blog...-maryw164.html
http://1972airstreamsovereign.blogspot.com/
Maryw164 is offline   Reply With Quote
Old 06-27-2009, 03:55 PM   #25
mello mike's Avatar
Phoenix , Arizona
Images: 14
Well, things were going great refurbishing my tail lights until I got the reverse lights. Yikes!!!! The rusty can for left reverse light practically disintegrated as I tried to pull it out. It's totally a loss. Got to scramble for a Plan B. Peterson replacement light or LED?
Old 06-27-2009, 06:41 PM   #26
Commercial Vendor
Profile:  Corona , California
Mike.
If you change the tail lights and back up lights to the sealed LED lights, you won't have another problem with them for probably 30 to 40 years.
By that time, you and I won't care.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 06-28-2009, 09:49 PM   #27
PizzaChop's Avatar
Images: 197
Mike,
Whatever your decision, I recommend you replace all of them if you intend to keep the unit. They'll match, and you'll never have to deal with it again. IMHO, one of the many better decisions I made with the Sovereign (as well as replacing all the marker lights).
Ron Kaes
Psalm 112
www.paparonnis.com
59 tail lights Jephellis Lights - Interior & Exterior 3 06-22-2008 08:29 PM
Tail lights, brake lights, turn signals on '75 22' mendosoft All Argosy Trailers 3 06-01-2008 09:46 PM
69 Tail lights. 69AmbassFl Lights - Interior & Exterior 12 03-26-2008 07:04 PM
Tail lights for 70 sovereign gparker Electrical - Systems, Generators, Batteries & Solar 11 11-06-2006 11:30 AM
Tail lights Chuck Electrical - Systems, Generators, Batteries & Solar 0 07-08-2002 02:58 PM
