Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 05-03-2008, 09:32 AM   #1
Lumatic
Lumatic's Avatar
Profile:  1971 25' Tradewind
1962 28' Ambassador
Estancia , New Mexico
71 tailight LED replacement
I found a LED unit that is about the same diameter of the original tailight on my 71. Has anybody done this update? Specifically, any suggestions about how to attach/ mount the LED unit in the 71 tailight housing?
Like a couple of Balboas we headed into the wild pavement of yonder with a monstous piece of aluminum hooked to our rear end. "The Long, Long Trailer".
Old 05-03-2008, 10:30 AM   #2
Wabbiteer
Wabbiteer's Avatar
Profile:  1973 27' Overlander
1972 29' Ambassador
Twin Mosquitos , Minnesota
I can not recommend the method I used but here it is...
I hand-fitted red LED pucks in the existing aluminum housings - took a power sander to the plastic and got the discs to fit square relative to the bumper.
I also removed the back-up lights and replaced with identical red running-stop-turn signal units so am trying a back-up light idea of using eBay cast aluminum AS marker lights put down low so I can see the bumper area better.
I had access to the reverse of the cast taillight assembly and cut away the bottoms of the cup - to weatherproof and make them theft resistant I've caulked them in place using (gasp) silicone caulk....
Powered by Tinnitus
RE & Alt Energy Hope Chest
RE Forums
Tailight Housing Removal toga Lights - Interior & Exterior 6 02-23-2008 05:58 PM
LED Replacement for Halogen Cabin Lights nangoff 2004 International CCD 12 01-13-2008 10:28 PM
80's tailight gasket? davidz71 Lights - Interior & Exterior 7 01-18-2007 10:13 PM
LED *Power On* lamp replacement Safari Tim Electrical - Systems, Generators, Batteries & Solar 4 03-31-2005 11:58 AM
Tailight Wiring '62 Overlander Deppdog Electrical - Systems, Generators, Batteries & Solar 2 07-17-2003 09:53 PM
