Old 10-05-2012, 09:08 PM   #1
john west's Avatar
1971 31' Sovereign
1971 31' Sovereign
Redding , California
'71 Sovereign wiring issue
i recently obtained two 1971 31' sov. internationals they both require the round pin plug for the 12 volt light wiring. Neither one of them match the wiring on my F-350 nor do they match each other! I have a bit of experience with this type of thing, but when I began testing the female plug on the coach, i have several pins that are direct to ground. I have been able to locate one trun/brake light, the back up lights and the marker lights. Not sure which wire is truly supposed to be the ground and where my other turn stop should be. ALso confused by the back up light thing. Never had them before and the current location should be the 12 volt charge line i beleive. I would love to have a wiring diagram of what the trailer wire was supposed to be so I have a starting point. I have reviewed previous posts on the subject for several hours and found diagrams either too blurry to make out or found the websites referenced at airstream to be deleted and no longer available. Any assistance would be appreciated.
john west is offline   Reply With Quote
Old 10-05-2012, 10:34 PM   #2
Maniacal Engineer
barts's Avatar
Menlo Park , California
This appears to be correct.... I spend some time devising a cable for our 1971; you will likely want to debug any problems in the trailer wiring before connecting to your tow vehicle. I found using a battery charger to test things nice, since there's a built-in current limiter.
http://www.airforums.com/forums/atta...2&d=1296789014
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
sovereign
Wiring diagram / schematic for a 76' Sovereign gronlampa Electrical - Systems, Generators, Batteries & Solar 1 09-07-2011 08:38 PM
1991 Excella 1000 - New Radio need wiring help! jbbaldwin Audio, Video & TV 0 07-13-2011 12:04 PM
What price for this Sovereign? Silverslug75 Trailer Values 3 06-22-2011 08:39 PM
A handy schematic snapshot from my furnace - 1970 Sovereign ranger_rick Furnaces, Heaters, Fireplaces & Air Conditioning 1 02-18-2011 10:34 PM
