Old 06-08-2011, 02:22 PM   #1
ckbailey97's Avatar
Scio , New York
7 Pin pdf - Trailer or plug view
http://www.airstream.com/docs/7wayplug1966-81.pdf
Is this looking at the male end (trailer) or the plug on the pigtail (in my hand) to connect to the trailer.
Just bought my first AS. 1971 Trade Wind 25 footer, and I need to get this home. Owner couldn't find the pigtail, so I am in the process of making it, but don't know what I am viewing.
Colin
ckbailey97 is offline   Reply With Quote
Old 06-08-2011, 04:00 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard
Looks like a girl to me...
Good luck bringing your new trailer home....
Post some pic's or 'ya can't stay..
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Just because you don't know how, doesn't mean you canít."
Amanamus
Sweet Streams....🌥
Old 06-08-2011, 04:29 PM   #3
Colin
Look "very" carefully at the back side of the connectors, provided they are the original "signal stat" or the Pollack connectors.
In small print, you will see the color listed next to each terminal.
Hook up the color wires as the connectors say, and you will be fine.
Old 06-08-2011, 06:09 PM   #4
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
plugs
I'm in the process of hooking mine up.
The white would be at the top and the red at the bottom as shown below.
If my other colors don't match it just because that is the way that we wired up the plug. Everything works (so far).
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 06-08-2011, 10:15 PM   #5
Splitrock's Avatar
Sioux Falls , South Dakota
I tested my tow vehicles with a 7-way tester. They tested okay. Then I wired the trailer plug with the tester. Then I wired the cord with the tester. The cord I bought had a molded end and when I tested the setup I had to reverse two wires in the cord plug. Now it all works and will work with any vehicle wired to a standard 7-way plug. It took a little time but it was all easy to do.
Old 06-09-2011, 04:12 AM   #6
ckbailey97's Avatar
Scio , New York
Thanks folks. Find out if everything goes smoothly tomorrow eve.
I know the tires are dry rotted, but here's hoping the rest is good once I get into it.
Will post photo's soon.
Thanks again for your time.
Colin
Old 06-13-2011, 12:14 PM   #7
ckbailey97's Avatar
Scio , New York
Picked it up, and got it home OK. Lights worked when I pulled it out of the parking spot, but then only marker lights worked. Limped it home that way, thinking it might be a ground issue, have to spend a few minutes and check what pins go where with a tester and a 12V supply, and make sure I have it hooked up right.
Truck & Trailer Weights nickmeloy Towing, Tow Vehicles & Hitches 6 04-02-2014 11:02 AM
Will my trailer get eaten alive now?? mile2885 Cleaning, Stripping & Polishing 12 06-03-2011 06:13 AM
'74 Outlander Door Latch Pin mtate Exterior Storage Compartments & Access Doors 0 04-13-2011 07:30 PM
A sad end to a wonderful trailer rmk110761 Airstream History 9 02-15-2011 10:12 AM
Which 7 way round pin out is for my airstream!?!? AirHome Electrical - Systems, Generators, Batteries & Solar 8 02-07-2011 10:22 AM
