Old 09-03-2010, 11:46 AM   #15
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Well, here's my solution to mounting the umbilical or pigtail. First, I wanted a system to allow removal of the umbilical to prevent damage from the intense Phoenix heat and to deter theft. I had a couple excellent choices, Brad's wedge idea or a straight mount similar to what you see on 70s Airstreams.
I already had a large hole on the curbside front where the old 4-wire plug was mounted (this plug provided 12v power from the tow vehicle directly to the trailer fuse panel for lighting). Using this old hole makes a lot of sense and gives me better access than where the original umbilical was hard wired to the trailer (the fresh water tank will be moved to under the streetside bed, freeing up space in the front for all of my electronics such as my 12v fuse panel and my inverter/chargers).
The pic shows my new Pollak 6-wire plug temporarily installed using the original 4-wire access hole. The extra screw holes have been temporarily closed with rivets and a screw (pop rivet gun broke again ), buck rivets will be installed later. My umbilical has a 7-wire connector on the vehicle side and 6-wire connector on the trailer side (reverse light wire not used of course).
The old hole where the old umbilical entered the coach will be used as an access point for the brake wire and for my battery wiring (my two batteries are mounted on the A-frame).
ID:	110005   Click image for larger version
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 09-03-2010, 12:53 PM   #16
Wise Elder
Jammer's Avatar
2010 30' Classic
Excellent work. Nice.
Old 09-03-2010, 01:15 PM   #17
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Thanks, Jammer. Actually, you gave me the idea to go with a 6-wire connector. I used your idea halfway with a 6-wire connector on the trailer side and a 7-wire connector on the vehicle side.
1958 Overlander
4CU 1st VP
Old 09-03-2010, 02:04 PM   #18
Wise Elder
Jammer's Avatar
2010 30' Classic
Well, now you have the perfect opportunity to compare how they perform. Post up when you find out which one fails first!
Old 09-03-2010, 04:50 PM   #19
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
My new Ford F150 came with a 7 blade plug and my Sovereign is already wired for 7 pins so it made sense to go with the 7-blade connector on the vehicle side of the umbilical for my '58.
1958 Overlander
4CU 1st VP
Old 09-03-2010, 04:56 PM   #20
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
Maybe Jammer was referring to round pin vs. flat pin?
SilverHoot is offline   Reply With Quote
9 pin to 7 pin conversion ck21084 Electrical - Systems, Generators, Batteries & Solar 4 06-10-2010 02:58 PM
6-pin connector to AS 7-pin Ruben J Towing, Tow Vehicles & Hitches 6 04-15-2009 10:29 PM
Adapting a 7 pin vehicle connector to a 9 pin Airstream connector PatandLane Lights - Interior & Exterior 3 03-22-2009 07:09 PM
'72 trailer 7 pin vs '99 truck 7 pin wiring? Hawkeye5 Lights - Interior & Exterior 4 08-02-2008 01:34 PM
Need 7 pin wiring help. TBKP's Overlander Electrical - Systems, Generators, Batteries & Solar 3 04-21-2003 01:27 PM
