Old 10-26-2015, 06:19 AM   #15
cmipilot
1975 27' Overlander
Flower Mound , Texas
I take your point on wire being a wire regardless of color. It just gets very confusing to try to diagnose the situation when the functionality doesn't follow the expected wire color. So how/where would the new harness be run, front to back? Along the frame? At the front, from the 7-way connector, do you just cut a hole in the bottom of the skin to run the wiring to the back? When you get to the back, where would be the best spot to penetrate the trailer skin to get up to the back side of the lights?
cmipilot is offline   Reply With Quote
Old 10-31-2015, 05:20 PM   #16
cmipilot
1975 27' Overlander
Update: As suspected, the wiring is not salvageable and needs to be replaced. Any thoughts on where to acquire a new wiring harness? Also, what are we talking about here as far as installation? Is this going to require taking skin off the belly and/or interior etc., or does someone have some first-hand experience accomplishing this job? Thanks for the good feedback so far.
Old 11-01-2015, 05:58 AM   #17
2005 25' Classic
1986 32' Excella
1965 22' Safari
Newark , Delaware
Is there any way to test the running lights, tail lights, turn signals, etc without plugging in to a tow vehicle? I am starting on a 65 Safari and it is already moved into the work area. Although I can get a truck back there, it won't be easy.
Chatooga11 is offline   Reply With Quote
Old 11-01-2015, 06:47 AM   #18
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Use a battery charger. Connect the black lead to a clean spot on the frame then connect the red lead to each of the wires on the UCord. See what works.
TG Twinkie is online now   Reply With Quote
Old 11-01-2015, 07:14 AM   #19
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
It will be easy to rewire the lights on the back of the trailer by running a new harness under the trailer, the top lights will be more challenging.
Brevi tempore!
Old 11-01-2015, 07:29 AM   #20
cmipilot
1975 27' Overlander
Under the trailer as in along the frame? Anyone have any photos of such a job in progress and then finished?
Old 11-01-2015, 08:14 AM   #21
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I have run a couple of 120V runs under my trailer, one for my inverter, and another for my Generator, I just put the wires in some type of conduit or protective sheathing and clamp it to the belly pan every foot or so.
Brevi tempore!
Old 11-01-2015, 11:09 AM   #22
EEC
EEC's Avatar
1969 31' Sovereign
Dover Foxcroft , Maine
I had a similar problem with recently acquired '69 Sovereign. Got one weak tail light signal to one of Andy's LED lights (which was a replacement for the rusted out original cans). Presumably bad ground. So with a new trailerside connector wired to match the umbilical cord, ran a four wire trailer cable down the middle of the interior floor, out the rear window and thru the back up light holes with a ground wire screwed into the housing. Now have running and brake/turn lamps working - so ready to bring home end of this week. (Obviously no back up, charge or brake connection at the moment.)
Would appreciate any thoughts on how to check original wires from front to back. Or good way to run new wiring to back of unit (preferably without doing too much to the interior panels).
Thanks in advance,
Ed
EEC is offline   Reply With Quote
7 Pin Round to 7 Blade Trailer Connector Adapter Needed Jeremy9107 Electrical - Systems, Generators, Batteries & Solar 14 07-25-2013 03:58 PM
Is there an adapter from the Airstream 7 pin on my '71 Safari to a 7 blade? MrJim 1969 - 1973 Safari 6 06-16-2013 08:15 PM
Trailer 7-pin round to truck 7-pin flat?? rogerdodger General Repair Forum 2 05-25-2012 03:42 PM
Adapting a 7 pin vehicle connector to a 9 pin Airstream connector PatandLane Lights - Interior & Exterior 3 03-22-2009 07:09 PM
'72 trailer 7 pin vs '99 truck 7 pin wiring? Hawkeye5 Lights - Interior & Exterior 4 08-02-2008 01:34 PM
