Old 02-25-2009, 06:55 PM   #15
1965 24' Tradewind
Warner , New Hampshire
Thank you for the pictures. I was thinking about having a local metal shop make some replica's out of aluminum. But I'm sure this would cost me a fortune. Your information will help. Thanks again.
briheath is offline   Reply With Quote
Old 02-25-2009, 08:26 PM   #16
kennyp315's Avatar
1965 20' Globetrotter
Woodland Hills , California
Images: 8
'65 Safari Tail Light Replacement Help
I had the same problem with my '65 Globetrotter with the cracked tail light housing. I unfortunately have finished the inside of my trailer and can't take the inside skins off again. A surfboard shaper is molding me covers that will fit over the housing and help close the sloppy gap between housing and rivets. I wish that I had done it right the first time. Also I did replace my stock tail lights with great looking LED's. I had a old aircraft machinist turn some aluminum doughnuts/brackets which came out nice. They are posted on Kip' '71 Globetrotter Full Monty Kenny
kennyp315 is offline   Reply With Quote
Old 03-31-2012, 09:14 AM   #17
kennyp315's Avatar
Images: 8
Smile '65 Safari Tail Light Replacement Help
Here is an my mold for '65 tail light housing repair. We made a reverse mold while on trailer. It would have been much easier to have done this while I had a bathroom skins out. I'm doing some remodeling on my trailer and thought that it was time to finish everything.
ID:	154697   Click image for larger version
Old 03-31-2012, 10:13 AM   #18
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
kennyp315 - Nice work!
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 04-02-2012, 09:35 AM   #19
kennyp315's Avatar
Images: 8
Thank you. The mold came out very nice. This is only the beginning, as we have to lay in the fiberglass very carefully to turn out each piece. It will take some work as even though each side is very close, they are slightly different. The good thing is that they will no longer leak, crack and be a mess. Also the 16th of an inch gap will be gone around the edge. It will look much better. I will post finished photo's soon.
Old 11-04-2012, 08:05 PM   #20
(-1 Rivet_
REDSLED88's Avatar
Jackson , California
Housing
I have my interior out, so I think I'm going to try and remove the thick black layer of adhesive on the inside, remove the rivets and get the housing out.
I'm thinking of maybe dipping them in something to strengthen them.
Mine are not dented, just have cracks which leak.
Any ideas on what I would dip them in?
I was thinking fiberglass would be great for repair, but then I'll just have to repair again as the fiberglass cracks. Plus the fiberglass will create a larger housing all around.
Since they are plastic, maybe some bondo to repair cracks, and then dip then.
But in what?
Anyone used Plasti Dip? http://www.plastidip.net.au/plasti-dip
TIMK
Thanks in advance!
TAC CA-77
REDSLED88 is offline   Reply With Quote
1971 Safari Axle Replacement pickerdd Axles 42 09-23-2015 05:47 PM
Safari Step Replacement Photo Guide TinLoaf Steps 7 07-18-2015 10:15 AM
Replacement Door for 1977 23' Safari KittyTexas Windows, Doors, Locks & Vents 3 12-19-2011 04:21 PM
Replacement tires for 2006 Safari 23 Goal15 Tires 0 05-16-2011 12:45 PM
LED replacement for '64 Auto-Lamp 7" taillight Globie64 Lights - Interior & Exterior 8 03-12-2011 07:37 PM
