Old 08-12-2014, 04:03 PM   #1
1964 19' Globetrotter
Fall Branch , Tennessee
'64 Globetrotter wired for a fan???
I have ordered a fan-tastic fan for my 64 Globetrotter, is it pre wired or will I need to wire it?
Rick0824 is offline   Reply With Quote
Old 08-12-2014, 04:16 PM   #2
64 Airstreams used a transformer that they called a "univolt".
That transformer had 2 secondary windings, one for 12 volts AC and the other for 19 volts AC.
The 12 volt wiring went to the lights. The 19 volt wiring went to the fans.
A 12 DC motor runs fairly well on 19 volts AC.
Yes, the trailer is wired for a fan, but I would use caution when using a fan-tastic fan.
Old 08-13-2014, 05:57 AM   #3
I am installing a 12 volt dc system. Since there is no fan in it now, I assume it was replaced with the skylight that is there now. I was hoping the wiring was there for a fan, sounds like it should be there. Thanks for your help.
g f r & g f i problems.....for the well wired folks.. 2airishuman Electrical - Systems, Generators, Batteries & Solar 61 03-25-2008 10:23 AM
Pre Wired for Heat 68 Safari soldiermedic Furnaces, Heaters, Fireplaces & Air Conditioning 3 11-21-2006 02:52 PM
Cross wired 64 trade wind advice, please! A-Merry-Can Electrical - Systems, Generators, Batteries & Solar 22 08-28-2006 10:54 AM
Urgent! Alternator/isolator wired incorrect! wa3vez Mechanics Corner - Engines, Transmission & More... 11 01-10-2005 08:39 AM
Properly wired? Bob Boucneau Electrical - Systems, Generators, Batteries & Solar 3 07-22-2003 10:39 AM
