Old 09-18-2007, 09:19 PM   #1
1963 19' Globetrotter
Moline , Illinois
Question 63 Globetrotter tail light problem
I have developed a problem in the right tail light in my trailer, the brake light and turn signal are working intermitently, the head light side works fine, also everything works fine on the left side light. Checked the socket and it had no power to the turn/brake signal side so I suspect either a short or loose connection somewhere.
How are these wires run to the rear lights? Do they come down the right side through the frame with the left connected to the right? What type of connection is used ? What is the easiest way to access the wiring to the left tail light? Any help is greatly appreciated. my bigest problem is how to get to the connections. The fix is the easy part.
63air is offline   Reply With Quote
Old 09-18-2007, 09:49 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
The wiring runs from under the frontbelly pan through the front floor near the support plate under the front window, then along the lower third of the streetside to the streetside taillight.
From there, wiring runs to the curb side taillight. The connectors are wire nuts just inside the round hole that becomes visible when you remove the taillight's base plate. You can carefully fish them out with needlenose pliers.
I am having continuing grounding issues with my right side taillight, so you might make sure that the lamps are properly grounded. It takes two to tango....power and ground.
Uwe
www.area63productions.com
Old 09-21-2007, 04:51 PM   #3
Moline , Illinois
Ground seems ok. Its working fine now so It is probably a connection. I've put about 30,000 miles on so likely a loose connector. Thanks for confirming my idea of how its wired. I've got an access panel on the belly pan in the right rear side so I hope I can get to things there.
Old 09-21-2007, 06:08 PM   #4
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Doubt that you can access the taillight wiring throug the rear belly pan. It runs between the inner and outer skin, about 1/3 of the way up from the floor, in a horizontally front to rear.
Uwe
LED tail light conversion Pahaska Electrical - Systems, Generators, Batteries & Solar 138 02-24-2018 06:03 PM
Tail Light Always On blueline Lights - Interior & Exterior 2 05-05-2007 03:55 PM
LED Tail Light Problem wdkueser Lights - Interior & Exterior 7 09-16-2006 06:58 PM
LED tail light conversion Excella CM 1978- 1979 Excella 500 0 06-13-2006 09:38 PM
'64 Globetrotter Patio Light Problem sdresen Lights - Interior & Exterior 1 07-26-2004 10:27 AM
