Old 06-11-2007, 04:01 PM   #29
1963 19' Globetrotter
Moline , Illinois
I have a 63 GT and have wondered about breakers as I did not find one by the battery. I have not had the small panel on the belly pan off to look there since everything is working fine. Should I have one by the battery? I'm not sure if I have a California trailer or not, the AS plate on the side says it was manufactured in Santa Fe , Cal. but when I called and inquired about a manual and gave the serial # 193D333 I was told it was an Ohio trailer, anyone know for sure? Did the plants do things differently?
I been thinking about a breaker by the battery and would like to use a
Blue Sea marine breaker that will also work as a battery switch since it is also designed for this ( they are used on high dollar boats for the trolling motors). Would 25 amps be the correct size? One last question, did both power circuits go to one breaker?
63air is offline   Reply With Quote
Old 06-11-2007, 08:59 PM   #30
calitrotter
1963gt's Avatar
Berkeley , California
you have an ohio trailer, judging by the serial.
i replaced my 25amp circuit breaker with a 30amp.
mianly because i counld not find a 25 easily.
i found nothing electrical behind any panel i removed from the belly (except the front one where the only accessible wires are)
the breaker near the battery is in the cabin next to the battery box, under the curbside gaucho.
i am interested in the breaker you mentioned..
hope that helps
mike
1963 Globetrotter OHIO
1988 Ford E150 Sportsmobile
2001 Buell X1 Lightning
2002 Isuzu Axiom 4x2
1963gt is offline   Reply With Quote
Old 06-13-2007, 10:04 AM   #31
Moline , Illinois
No breaker anywhere so I will go the Blue Sea route. Thanks for manufacturing info.
Old 06-20-2007, 09:48 PM   #32
Dan Clayton's Avatar
1956 22' Flying Cloud
West Linn , Oregon
Images: 14
So you need a wiring diagram, well I got one some place. I had a 1963 Globetrotter, and I took a few copies of the diagram. Give me a day or so and I think I can find it. I have since sold that trailer, and am working on a 1956 Flying Cloud, and would ya know it Im working on all new wiring as we speak. You can check out pictures of both trailers under search, Dan Clayton
Dan Clayton is offline   Reply With Quote
12v
1963 Airstream Globe Trotter - Where Can I find these Parts Uncle_Phil 1960 - 1964 Globetrotter 12 03-27-2014 04:39 PM
Serial number of 1960s Globe Trotter ? What year is it ? oldvws Our Community 1 12-12-2002 08:25 PM
12v vs 120 jane babinski Electrical - Systems, Generators, Batteries & Solar 13 09-30-2002 09:23 AM
12V question uwe Electrical - Systems, Generators, Batteries & Solar 16 09-05-2002 01:14 PM
Inside door handle for a 1984 International Bennie 1980-1984 International 0 08-06-2002 08:37 PM
