Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 06-22-2008, 06:02 PM   #1
Jephellis
Jephellis's Avatar
Profile:  1959 18' "Footer"
Carbondale , Colorado
Images: 48
59 tail lights
I'm restoring a beauty of a '59 18-Footer, got the tail lights working for a while but this weekend had to take a closer look and ended up pulling the wires and removing the sockets from the base plates of the Bargman #99 assemblies.
?#1) Are these originals?
?#2) Can I find base plate replacements? (I don't want to use paint can lids, just don't want to).
?#3) If I can't replace, where do I find bulb sockets to replace into the base plate?
PS is there a picture attached? I think I attached a photo of the lens and the plate........
Jephellis
Jephellis is offline   Reply With Quote
Old 06-22-2008, 06:53 PM   #2
overlander63
Rivet Masher
overlander63's Avatar
Profile:  1974 31' Sovereign
L.A. , California
Welcome to the forums.
Yes, there is a picture of a Bargman 99. You can re-use the old backing plate, and your local NAPA will have the sockets. If you want to replace the lenses, Yankee Lighting (number99 here on the forums) sells reproductions using the original molds at a reasonable price.
Old 06-22-2008, 08:18 PM   #3
flyfshr
flyfshr's Avatar
Profile:  1959 24' Tradewind
Phoenix , Arizona
First of all, welcome aboard, Great to have another '59er around. Second, yes, those are both original to a '59 trailer. As Terry mentioned, replacement lenses are available but the base hasn't been available for some time. You'll need to do all you can to keep them in working order. The one in the picture doesn't look too bad, I've certainly seen much worse.
Best of luck in your taillight efforts.
FF
WBCCI/VAC #2699
Air #10
I'm haunted by aluminum.
http://www.airztream.com
http://59tradewind.blogspot.com
flyfshr is offline   Reply With Quote
Old 06-22-2008, 08:29 PM   #4
Jephellis
Jephellis's Avatar
Images: 48
Thanks guys
Thanks guys!
I'm not only new to this site but new to Airstreams, been dreaming of finding an old one for years and finally did! The restoration is one major project but a great bonding experience with my tools, and wife to be honest!
This forum rocks, can't wait to learn and share more as the project continues!!
Thanks again,
Jephellis
Tail lights, brake lights, turn signals on '75 22' mendosoft All Argosy Trailers 3 06-01-2008 09:46 PM
69 Tail lights. 69AmbassFl Lights - Interior & Exterior 12 03-26-2008 07:04 PM
Tail lights for 70 sovereign gparker Electrical - Systems, Generators, Batteries & Solar 11 11-06-2006 11:30 AM
Autolamp Tail Lights? 66Overlander Electrical - Systems, Generators, Batteries & Solar 8 04-20-2004 05:54 PM
Tail lights Chuck Electrical - Systems, Generators, Batteries & Solar 0 07-08-2002 02:58 PM
