Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 07-25-2007, 01:25 PM   #1
startrekker2001's Avatar
Profile:  1978 31' Excella 500
Palm Bay , Florida
Images: 34
4" by 4" LED Taillights for Vintage Trailers.
I have installed taillights I bought at Tractor Supply Company and they work great. The body of the light has to be modified slightly to fit but it is easy to do. The model I got from TSC had one 4 LED light attached to the main body for a license plate light.
Here is a link to my website where I have pictures and instructions.
LED Taillight upgrade
Vic Smith
WBCCI #6782
31' 78 Airstream Excella 500
2001 Ford Excursion V-10
Reese hitch and dual cam sway control
startrekker2001 is offline   Reply With Quote
Old 07-25-2007, 02:26 PM   #2
Excella CM's Avatar
Venice , California
Nice upgrade. The step by step is very helpful. Good work!
"Not all who are laudering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 07-25-2007, 02:30 PM   #3
The Hawk's Lair
cooperhawk's Avatar
Profile:  BACK WOODS , Minnesota
Interesting. I did the exact same modification on our motorhome last winter. They look great too! I bought the same lights from tractor supply. The liscense plate leds now illuminate over my door.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 07-25-2007, 02:48 PM   #4
1983 Sovereign 31'
Mac1's Avatar
Profile:  1984 31' Sovereign
Mount Olive , North Carolina
Great Post Vic, I wondered what the best way to go with LED was and you have a timely post.
Mac
Mac and Linda Cassell
WBCCI # 3292 AIR#16287
Buckeye (Chesapeake Bay Retreiver)
1983 31' Sovereign (Carmen O)
2006 2500HD Duramax SLT CC 4x4 (Brutus B)
Mount Olive, NC 28365
"Pickle Capital of the World"
Mac1 is offline   Reply With Quote
Old 07-25-2007, 05:06 PM   #5
vswingfield's Avatar
Profile:  1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Hi Vic,
Thanks for the step by step instructions. Very helpful. Sorry about the owie on your thumb.
Vaughan
vswingfield is online now   Reply With Quote
Old 09-01-2007, 09:18 PM   #6
SmokelessJoe's Avatar
Profile:  1976 Argosy 24
TORONTO and Southwestern , Ontario
LED turn signals for an ARGOSY
Tractor Supply Company in Canada and the United States are under different ownerships and TSC in Canada doesn’t carry the item Vic found.
For Canadians, I found what I suspect is the same item under the Power Fist house brand name at PRINCESS AUTO, a large chain operation.
It’s a Submersible Trailer LED kit. Fittings, cable, everything for $54.99.
The lens is within a 1/16” of the Monarch #9075 original!
On first examination it appears that the fiberglass bezel on the ARGOSY can be slightly modified to receive the whole unit even more easily than modifying the Monarch housing to take the LED components.
I’ll confirm if that’s the case later.
Sergei
SmokelessJoe is offline   Reply With Quote
Old 09-05-2007, 05:01 AM   #7
Profile:  1962 22' Safari
Anchorage , Alaska
Trying to install L.E.D.s also, need help.
I am trying to retro. some leds on a 1962 Safari. I have tail, faint turn, but when I apply breaks they simply go out. Any ideas? Thanks in advance. I will try to get model and pics info if interested. The lamps I have purchased have S/T/T and Back-up on the outside. They also line up with the factory holes for the original lights (I think they are refered to as "wedding cake" lights). I need to rig my lights so I an trek to Tucson last Sunday! I am late.
Airstreaman is offline   Reply With Quote
Old 09-05-2007, 02:27 PM   #8
richinny's Avatar
Profile:  1994 34' Limited
Westchester Cty. NY , & Miami FL
check your ground, it might be bad or poor. try running a test wire from a known good ground.
Ricky
Ingrid - my unofficial '"World's Oldest Airstreamer"
January 1909 - October 2008 R.I.P.
Argosy trailers 83Excella All Argosy Trailers 33 07-20-2003 10:43 AM
Trailers to avoid Jabba Airstream Motorhome Forums 11 11-01-2002 08:38 AM
Small LED above water heater compartment smily General Repair Forum 16 09-24-2002 01:30 PM
numbers on trailers maznblu WBCCI Forum 2 06-03-2002 12:42 PM
Figuring out what is going on with my trailers electric setup... Andy R Electrical - Systems, Generators, Batteries & Solar 1 03-30-2002 10:59 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
