Old 01-17-2011, 12:44 PM   #15
MonaxLisa's Avatar
1975 31' Excella 500
undetermined , Washington
I did try backing the end off of the new switch, it just clicks so I guess it's on there pretty good...which is fine, it'll match the others once I have to replace them :-p
This new switch was only about $8 so that was nice!
MonaxLisa is offline   Reply With Quote
Old 01-17-2011, 12:56 PM   #16
Sorry, but that's the wrong switch.
The correct rating should be 3 amps 250 volts AC and 6 amps at 125 volts AC.
The attached photo shows you those ratings.
Under rated switches, heat up, and they too, can cause a fire.
Old 01-17-2011, 02:24 PM   #17
Hopefully this photo takes.
This is the correct switch for the ceiling lights, 1975 and older to 1965.
Andy 11K
Old 01-17-2011, 03:12 PM   #18
MonaxLisa's Avatar
Andy 11K
Well crap...I guess I'll look again, this switch didn't have anything printed on it, just on the bag, above where it says not made in the USA
Old 01-17-2011, 08:08 PM   #19
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
What markings - if any - are on the old switch..?
Old 01-17-2011, 09:50 PM   #20
MonaxLisa's Avatar
none :/
Old 01-18-2011, 08:02 AM   #21
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Have an Ace hardware anywhere close - knob still won't fit:
Gb-Gardner Bender GSW-62 On/On/On/Off Rotary Switch
Old 01-18-2011, 05:24 PM   #22
MonaxLisa's Avatar
Wow, look at that price...I went to an Ace to get the switch I got, but since the one I got was the only one they had I'll have to look at a different Ace!
Old 01-20-2011, 02:42 PM   #23
MonaxLisa's Avatar
I found the numbers on my old switch, it does say 1A-250V-3A-125V so the switch I got should be fine, yay! Unfortunately it feels like my kitchen switch is about to go and I can't find another switch anywhere! Guess I bought the last one in the county (and the next county!)
Old 01-20-2011, 03:00 PM   #24
The old switch you have, "IS NOT" the correct switch.
The ratings should be as you see them in the photo, posted above, as per Airstream.
Old 01-20-2011, 04:51 PM   #25
MonaxLisa's Avatar
Thanks Andy, that's the size I'll look for then, if I can ever find one.
I stopped at six places yesterday and each one kept telling me I didn't know what I wanted. One person actually told me that I didn't want a light switch, I wanted a fan switch. Ahhh!
1956 Bubble Restoration Start to Finish the544man 1955 - 1957 Bubble 361 04-13-2018 06:47 PM
Overhead Light Switch "HI-LIGHT-LO" motilley Lights - Interior & Exterior 14 08-23-2017 06:11 AM
replacing black water tank in 68 Tradewind clydecrashcu Waste Systems, Tanks & Totes 1 01-17-2011 09:28 PM
Battery switch behind the sofa LawChick Batteries, Univolts, Converters & Inverters 9 01-13-2011 08:52 PM
