Old 05-22-2016, 08:51 PM   #1
PA BAMBI II's Avatar
1964 17' Bambi II
Strasburg , Pennsylvania
1964 12 volt interior sconce lights shut off intermittently
I think the 12 volt interior sconce lights in the 1964 Bambi II did the same last camping season...they shut off and then come back on at will. Jiggling the lights' turn-knob switch will also correct the problem.
Once back on, either autonomously or by jiggling the switch, they will stay on for a few minutes and then the same thing happens again. The inventor sounds differently when the bulb goes out.
The lights are quite warm/hot when they do this. I am wondering if I have a problem in the switch, it if there is some kind of safety shut off feature in the switch...doubtful for 1964 technology...or if it is a bulb heat problem and should I try changing to LEDs??
Any help appreciated.
PA BAMBI II is offline   Reply With Quote
Old 05-23-2016, 07:30 AM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I will assume these are 12 volt DC lights and it is the converter changing sound.
It sounds to me like you have a bad connection either on the common/ground side or the +12 volt side. The skin provides the common/ground so check for a lose connection. It could be as simple as the mounting screw is lose.
Old 05-24-2016, 02:04 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Fix for bad center terminal
Here ya go..
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-26-2016, 06:22 AM   #4
1964 17' Bambi II
Originally Posted by cwf View Post
Here ya go..
So you're saying I have a bad center terminal? Would that explain my light's symptoms?
"The difference between vintage and retro is that vintage is honestly old and cool. Retro tries to be but isn't."
Old 05-26-2016, 05:41 PM   #5
1973 31' Sovereign
Middletown , California
Sounds like some connection is getting hot and changing shape cutting off electricity flow. Try to jiggle things one at a time to find offender. Could be bulb to base or center contact, switch contacts, wire connection or even fuse contact in converter. Close observation is necessary.
ijustlee is offline   Reply With Quote
12 volt, 1964
Wanted: 1964 12V wall sconce PA BAMBI II Lights - Interior & Exterior 2 08-06-2015 05:25 AM
Double Sconce Lights 1964 Globetrotter tmeagle1 Airstream Classifieds 0 06-15-2015 12:55 PM
Furnace goes off intermittently? LI Pets Furnaces, Heaters, Fireplaces & Air Conditioning 6 01-30-2010 04:17 AM
? about sconce lights in 59 traveler r&kweber General Interior Topics 11 08-13-2006 07:19 PM
1960 Wall Sconce Lighting mmth11053 Electrical - Systems, Generators, Batteries & Solar 3 03-30-2006 06:52 PM
