Old 02-01-2011, 11:58 AM   #15
ddstech's Avatar
1958 22' Flying Cloud
Folsom , California
LED Bulb
Originally Posted by BradS View Post
mattkroff could you please share the socket and bulb part # that you used.
I have a 57 Overlander with the same light and I would love to put an LED in it.
Here you go.
1156-W3X1W Is the bulb
BA15 base Wired Sockets
The socket was .99
the bulb was around 15-18 dollars.
I just bent the tabs to fit and line up with the existing screw hole in the fixture, then used a hehr window screw and nut I had laying around to attach it. I will go to Home depot today and get a proper Stainless steel screw and nut that will provide longer lasting results. Because its a tight fit, consider using some locktite to secure it.
Good luck.
Matt
ddstech is offline   Reply With Quote
Old 02-01-2011, 12:13 PM   #16
Lothlorian's Avatar
Loganville , Georgia
Norm and Matt:
Where did you get your exterior metal light. I need one for my trailer. I can't seem to find one.
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 02-01-2011, 12:20 PM   #17
nmbosa's Avatar
Nowhere , Washington
Originally Posted by Lothlorian View Post
Norm and Matt:
Brian
Mine was on the trailer when I bought it. I'm pretty sure it is original since it looks exactly like so many other 50's Airstream porch lights. Like Matt, I had mine re-chromed and convereted it to 12v.
Norm
Norm and Mary
blog: Captain Wilson's Overlander
nmbosa is offline   Reply With Quote
Old 02-01-2011, 03:28 PM   #18
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
Thanks Matt
Thats what I was looking for I like what you did and hope to do the same
My 57 Overlander thread ( Holly is her name)
http://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Old 02-01-2011, 03:56 PM   #19
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Hate to break the news to you, Brian....those lights are "gold." if you find one buy it!
Then, again....if your not a purist....look at the various air vents on EBAY...for boats .
There are some real nice, very similar to the lights, vents out there. Make your own.
Old 02-01-2011, 04:51 PM   #20
Lothlorian's Avatar
Melody:
I found the light we are going with . It will be perfect. check it out.
Andros LED
Brian
Brian & Adrienne
Old 02-01-2011, 06:07 PM   #21
Ken J's Avatar
Durango , Colorado
Images: 14
Wow - even the same year has different sockets.... As I said 50's models could be very different from each other - is yours an Ohio model?
Ken J.
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 02-01-2011, 09:33 PM   #22
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Ken J.
No, mine is a CA model.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 02-02-2011, 07:46 AM   #23
Ken J's Avatar
Durango , Colorado
Images: 14
Wow so is mine - will have to compare serial numbers sometime to see how far apart they were born....
Ken J.
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 02-02-2011, 12:59 PM   #24
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Ken J.
My Overlander VIN is 26-7162.
1958 Overlander
4CU 1st VP
Old 02-02-2011, 01:50 PM   #25
Ken J's Avatar
Durango , Colorado
Images: 14
Mine is 7076 - just 86 trailers different..... I don't know where the numbers started - but I would imagine we are in at least the first half of 58
Ken J.
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
1958, 1958 overlander, porch light
Tail Light Monitors? MDSilverado Lights - Interior & Exterior 3 10-19-2015 07:15 PM
How to Light the Pilot in the Oven lcurrie Stoves, Ovens & Microwaves 3 08-01-2011 07:16 PM
LED light upgrade BarnacleBill Lights - Interior & Exterior 11 01-31-2011 10:50 AM
Flash of Light !! donking General Repair Forum 8 01-24-2011 02:16 PM
Panel indicator light for water pump and Water heater DJW Water Heaters, Filters & Pumps 3 01-05-2011 07:01 PM
