Old 12-07-2011, 06:19 PM   #57
1955 18' Wanderer
Carthage , North Carolina
Is anyone repopping the bases yet?
zgears is offline   Reply With Quote
Old 05-13-2014, 10:45 AM   #58
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I have four new condition bases. I am searching for someplace to send they for reproduction. Anybody have a reference? Thanks.
Old 05-13-2014, 11:10 AM   #59
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
So with this expertise is anyone capable of reproducing AutoLamp 575 wedding cake tail light lenses?
BambiTex is offline   Reply With Quote
Old 05-13-2014, 08:13 PM   #60
Birdie Momma
NJtoNC's Avatar
1957 26' Overlander
Rutherford Co. , North Carolina
Melody ranch
Have you contacted Steve at VTS ? Or are you looking for a unique biz venture of your own?either way its awfully thoughtful of you to consider the greater good with your original bases. I hope that you are able to find someone to make them. Sorry im no help.
'57 Overlander | '56 Flying Cloud | '51 Spartanette
NJtoNC is offline   Reply With Quote
Old 05-13-2014, 11:32 PM   #61
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
3-D printing, anyone?
Old 05-19-2014, 07:13 AM   #62
Vintage Trailer Supply
VintageRV's Avatar
1956 22' Caravanner
Montpelier , Vermont
3D printing for the bases is an interesting idea. The amount of post-print work that would have to be done would be substantial. An ABS base made on a cheap 3D printer would be inexpensive to make but would be low resolution so you'd need to sand it down substantially and then do wiring....and paint it to protect from the UV.
Mid-price print jobs are higher resolution but would not hold up in service.
High-end print jobs would work but not really be very affordable. Send me a pic of the base and I can advise best path.
As for the 575 lenses...not sure how the optical quality printing is priced, but I know building the model would be expensive.
Your best bet for both these parts is hand casting or machining the bases. Frank provided an original lens so we could make the lenses. If someone can lend a base, we can do the same for that.
The 575 is tougher. I tried to hand cast that one and I failed due to the wall heights. Made me sad because I like the quilted look on some of them.
Steve Hingtgen
WBCCI #1573
VintageRV is offline   Reply With Quote
Old 05-19-2014, 08:15 AM   #63
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I have the bases if you need one for a pattern. Am trying to find a place here to re-pop them.
Old 05-19-2014, 04:53 PM   #64
Baltimore , Maryland
I have the bases too Steve...
Old 05-26-2014, 03:21 PM   #65
Star-Man's Avatar
1953 21' Flying Cloud
Encinitas , California
Can someone post a photo of a base. I don't know what it looks like. I can get the dimensions from a lens and try to make a Solidworks model and send to Shapeways to get a cost for 3D printing in stainless.
Star-Man is offline   Reply With Quote
1954, 1955, marker light, vintage
