Old 11-05-2012, 11:44 AM   #1
1968 28' Ambassador
Shreveport , Louisiana
12V lights without battery?
I have a 68 model Ambassador and have a basic question. Will the 12v lights operate without a battery installed, but plugged into a 120v source? What # bulb would be the correct size and type. Thanks, Bill
Headhog is offline   Reply With Quote
Old 11-05-2012, 11:51 AM   #2
1974 Argosy 20
Kooskia , Idaho
If it has the original Univolt installed and it is operating, the lights should work without the battery. Be sure the battery cables are not touching each other, or any metal parts of the trailer.
Old 11-05-2012, 11:55 AM   #3
1968 28' Ambassador
Thanks. It does have the Univolt, but don't know if any of the bulbs are any good. Do you happen to know which bulb would work? The trailer is not where I am, but might try taking some bulbs when I go Wed.
Old 11-05-2012, 12:09 PM   #4
1988 25' Excella
Trumbull , Connecticut
Hello Headhog. On some univolt converters the battery was required to help regulate the voltage and kep the voltage from going to high. You may want to check the voltage at a light, with the battery disconnected, to make sure that it's not much over 13-14vdc. In the manual to my 1988 excella it cautions you not to run the radio and other 12 vdc items with the battery remover for fear of damage to the equipment, not the univolt as they are almost bulletproof.
Good luck nm1oqrz
nm1oqrz is offline   Reply With Quote
Old 11-05-2012, 12:32 PM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
1156 bulbs will fit in the original interior fixtures, I believe.
Old 11-05-2012, 02:20 PM   #6
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
1141 bulbs, are in my 68
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 11-05-2012, 06:14 PM   #7
1968 28' Ambassador
Thanks for everyone's help. Trailer hasn't been used in a while and I was told that the 12v lights didn't work. This will give me a starting point for trying to figure it out. Will be using a Honda 2000 for some 110 so I can at least have some coffee! Bill
Old 11-12-2012, 09:11 PM   #8
1971 29' Ambassador
guyton , Georgia
coffee and candle light nothing wrong with that
r.swanson is offline   Reply With Quote
Old 11-13-2012, 07:09 AM   #9
1968 28' Ambassador
Although there is not a battery installed, the Univolt doesn't seem to be putting out 12v current. Now, it doesn't seem to be a bulb issue. Thanks as always for your help. Bill
12v
Battery charger for 12V power supply? Cha-Ching Waste Systems, Tanks & Totes 5 02-04-2012 11:15 AM
Should interior lights work with no battery but with Tow Vehicle connected bocotim Electrical - Systems, Generators, Batteries & Solar 12 11-03-2011 10:06 AM
Battery Bank Upgrade Gwuk Batteries, Univolts, Converters & Inverters 5 03-24-2011 08:18 AM
