Old 07-30-2010, 10:25 AM   #1
ole81's Avatar
1981 31' Excella II
Richmond , Texas
12V lights and water pump
Our 12v ceiling lights flickere when we turn on the water pump. Is this normal, or do we have a problem?
Bob (K5RPS) and Gail (MAAAA)
31' 1981 Excella II
2001 F-250 7.3D Crew w/8'bed and Pullrite 180degree
"Ask the Man Who Owns One" (Packard, Of Course)
or
"Ask the Woman who lives with one...or more!" (Gail)
ole81 is offline   Reply With Quote
Old 07-30-2010, 10:29 AM   #2
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
It's an Airstream, so both
TX-16
Dave Park is offline   Reply With Quote
Old 07-30-2010, 11:08 AM   #3
Maniacal Engineer
barts's Avatar
Menlo Park , California
The start current on the 12V water pump is large; this causes voltage fluctuations on the line and the resulting light flicker. This is normal and expected; you can see the same effect at home with loads w/ high in-rush currents such as circular saws, etc.
If it bothers you, you may be able to reduce the problem with one of those $20 2F capacitors used by the car stereo nuts to provide more drive for their woofers; attach this at the pump to the power supply line (BEFORE the switch) and to the local ground. Personally, I don't feel it is worth worrying about...
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 07-30-2010, 02:21 PM   #4
2008 16' Safari
Destrehan , Louisiana
You could have a little corrosion on any (or all) of the wires in the DC circuit. I'd check all of the battery terminals, binding post and all of the wire terminations in the DC distribution panel. The lights are flickering because of a voltage drop. The water pump should not draw enough current to load the DC buss and make the lights dim.
Neither of my AS trailers ever had this problem when the DC buss, water pump, batteries and charger were all working correctly.
dlb435 is offline   Reply With Quote
Old 07-30-2010, 02:39 PM   #5
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
I agree with dlb435 sounds like a bad ground or weak battery.
Garry
Old 08-03-2010, 03:24 PM   #6
1978 31' Excella 500
SOUTH ANHERST , Ohio
electrical issue
Originally Posted by dave park View Post
it's an airstream, so both
i have a 1975 argosy and the following all worked and now do not ????????? They are as follows the range hood fan
light over the sink
galley fan
fresh water pump
light in bed room
all other light work ????
I think it is a blown fuse , but can not find the fuse panel in this 1975 argosy ?????? Any ideas ????
Gosman is offline   Reply With Quote
Old 01-27-2013, 10:49 PM   #7
mtbguy's Avatar
Dunwoody , Georgia
I have this problem now also!
Reviving an old post here. I just brought home my new (to me) 1976 Argosy 26. Have been replacing plumbing with PEX and working on all kinds of small projects. My 12V lights (and everything else) worked when I put in fresh, new charged battery. I noticed the TV antenna no longer worked and was leaking a bit, so I removed it and installed a cover on the roof. The insulation was a bit damp around the hole so I ran a hair dryer on it for awhile.
The next day, my overhead lights, and water pump no longer function. Does this sound like damp insulation still or a blown fuse in converter? I looked at fuses but did not test them.
Rick
mtbguy is offline   Reply With Quote
12v
Freaky 12v lights flickering and fading out RichHog Batteries, Univolts, Converters & Inverters 15 12-13-2011 11:19 AM
I want my water pump switch to light up... Friday Electrical - Systems, Generators, Batteries & Solar 18 09-18-2011 11:03 PM
'08 Safari water heater only staying lit for 3 mins... bonginator Water Heaters, Filters & Pumps 3 08-21-2011 08:51 PM
Another @!#*& water heater pilot that goes out! Aage Water Heaters, Filters & Pumps 36 08-11-2011 11:51 PM
Water pump wiring question pageclot Water Heaters, Filters & Pumps 6 04-26-2011 08:11 PM
