Old 05-21-2011, 07:41 PM   #1
1978 28' Ambassador
mcconnelsville , Ohio
12V/110V lights
Have my plumbing issues under control thanks to so very helpful information from these forums now I am working on the electrical systems. I can not get the lights to work on 110 hook up. 12 volt they all work fine except the exterior lights. the outlets and AC work fine but no lights. Am I missing something?
Dave
mohrjr is offline   Reply With Quote
Old 05-21-2011, 07:51 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The lights inside the trailer are 12 volt lights. There should be no 120 volt lights, so if the lights don't, you have a 12 volt issue. Check your fuses, including the 50 amp negative fuse.
Old 05-21-2011, 09:11 PM   #3
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
There may be another 110V breaker box, on the opposite end of your trailer.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 05-21-2011, 09:43 PM   #4
Dan@LED4RV's Avatar
Denton , North Carolina
chasing electricity
Dave
When it comes to electricitial problems I always thinking of chasing it. I would start with what you know. Get the old meter and see if you have 110. If you do have 110, then find the power converter. I hope I'm wrong but it sounds like the converter. Check the power going in, the if you have 110vac, then check it coming out. Depending on what type converter you have you should have around 13 volts vdc or a little better.
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 05-22-2011, 06:12 AM   #5
1978 28' Ambassador
Thanks for the help. I have checked all the fuses in the low voltage distribution panel with an ohm meter and all are ok. I also checked the power coming into 120 v breaker panel and the breakers and all seem to check out okay as far as I can tell. ( I'm no electrician but do have basic knoweledge) The AC power light does not light when on city power? The microwave, outlets and Air unit all work. I have no idea where the converter is located on our 1978 Ambassador rear bath unit. Any help is appreciated.
thanks,
Dave
Old 05-22-2011, 06:23 AM   #6
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Like Terry said, the lights are all 12 volts. They run off the battery and converter. Many of the 70s have the converter in the bath area, in a closet or under near the tub. If it is the original, you should be able to hear it hum when it is working.
Richard
Old 05-22-2011, 06:58 AM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Univolt
If it is the original Univolt it will be humming if there is 120 volt power to it. Look in storage areas like closets. It should be relatively close to the battery, I would think.
Old 05-22-2011, 07:13 AM   #8
Well Preserved
1993 21' Sovereign
Many of these trailers have shutoff switches for the converter. It may be near the front couch, or in the medicine cabinet. That still won't stop the 12 volt system from working until the battery goes dead, however. You DO have a battery installed in your trailer? It IS connected, and the terminals are clean?
Old 05-22-2011, 08:36 AM   #9
1978 28' Ambassador
Thanks again, No humming anywhere, Yes the battery is connected and in good working condition. Could not find a shut off switch anywhere. I'll continue to look.
The battery hook up is in the front outside compartment by the LP tanks. The 12 volt distribution panel is in the front of the trailer behind the couch. The 110v breaker box is in the rear bath under and to the right of the sink. Should the converter be close to the 12v fuse panel in the front?
thanks
dave
Old 05-22-2011, 09:24 AM   #10
2002 25' Safari
Dewey , Arizona
Images: 62
In the later 70s they moved the battery up front...
There should be 2 large wires on the back of the 12volt distribution (fuse) panel. They should attach to the converter.
Richard
Old 05-22-2011, 09:26 AM   #11
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
On my 1979 Safari, the converter is in a compartment directly under the fuse panel.
Bill
thanks
dave
Just my personal opinion
Old 05-22-2011, 10:12 AM   #12
1978 28' Ambassador
Well I found the converter! Looks like I will be taking the front bed out at some point. I will tackle this job at a later date. Thanks for all the help and feedback. Time to move on to the water heater.
Old 05-22-2011, 10:47 PM   #13
NevadaGeo's Avatar
Genoa , Nevada
There's a light switch that turns on the univolt in mine, next to the 12V fuse panel above the univolt. But my 110V lights go out when the breaker in the rear trips.
NevadaGeo
12v
Electrical issues with clearance lights 1987_345 Classic Motorhomes 13 08-25-2011 08:13 AM
LED interior lights: A complaint hampstead38 Lights - Interior & Exterior 0 03-23-2011 08:38 AM
Minus these lights SilverHoot Lights - Interior & Exterior 20 02-13-2011 09:04 AM
Moving from center lights to multiple puck lights mikeandnora Lights - Interior & Exterior 10 02-11-2011 09:47 AM
Bedroom lights won't work! julieibach Lights - Interior & Exterior 1 01-24-2011 10:14 PM
