Old 02-03-2014, 03:07 PM   #1
Dan S's Avatar
1975 Argosy 26
Normandy Park , Washington
12 volt splice
I want to run a LED strip over my refrigerator area but there is not a power source nearby. Is it as easy as finding the closest source (over the twin bed) and splice into it and run the wire in the overhead bins and drop it in?do I need to consider distance and wire size etc?
Thx
Dan
Dan S is offline   Reply With Quote
Old 02-03-2014, 03:28 PM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Thx
Dan
For an LED strip all you really have to consider is making the splice clean, tight and well-insulated when you're done. The draw for LEDs is so low that you'd have to work to find wire small enough to overload it. Since it's easiest to splice wires of similar gauge, get wire to roughly match what you're splicing into and it should be fine. For a semi-permanent connection, pros recommend the crimp-and-solder connectors.
David
Old 02-03-2014, 03:53 PM   #3
1974 Argosy 20
Kooskia , Idaho
Yes, as DKB said, LED lights take very little power to operate so that is not the real issue of concern. You do need to use a wire which will handle at least 15 amps which is most likely the fuse size for the original circuits in the AS. The wire needs to be able to cary enough current to blow the fuse in case of a short between where you splice it into an existing circuit and the LED's you want to operate. Given that, I suggest #14 wire, although #16 would probably cary enough current for a short time to pop the fuse in the event of a short.
Old 02-03-2014, 05:17 PM   #4
truckasaurus's Avatar
1960 33' Custom
Saskatoon , Saskatchewan
And in wall rated.
truckasaurus is offline   Reply With Quote
Old 02-03-2014, 07:41 PM   #5
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I prefer two or three layers of shrink tube on a long splice using cross link wire.
Old 02-03-2014, 07:59 PM   #6
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
You also have to pay attention to polarity LED's can be hooked up backwards and self destruct.
Garry
12 volt
12 volt TV looking to buy Lothlorian Electronics & Connectivity 47 03-28-2012 09:10 PM
Is it okay to have 12 volt light grounded to skin or frame.. Bill M. Lights - Interior & Exterior 1 09-14-2011 02:27 PM
12 volt panel location kmoore Electrical - Systems, Generators, Batteries & Solar 5 08-24-2011 09:45 PM
Volt meter on battery box Denis4x4 Batteries, Univolts, Converters & Inverters 0 07-14-2011 12:56 PM
1974 Sovereign 12 volt battery pigtail Shamock Batteries, Univolts, Converters & Inverters 3 06-24-2011 05:08 PM
