Old 05-27-2017, 05:40 PM   #1
vincaroo's Avatar
1991 25' Excella
1995 34' Excella
Atlanta , Georgia
12 volt LED not dimming???
Hello All,
I have a 1991 25 ft Excella. I upgraded all the lights to LED and most of them have worked great. My dinette light was upgraded to 6 LED (3 watt bulbs, then I changed them to 2 watt bulbs.....1 total amp, so not a big load). I have tried three different brands/makes of remote control dimmers and they don't work. The light works, and light up by default when the power is on. I have a manual switch that works to turn them on and off. However, my PWM dimmre doesn't do anything. While the lights come on when supplied, the PWMD remote control doesn't dim, brighten, or turn the lights on or off. I'm thinking I did something wrong when I rewired them, but I can't figure it out. Any suggestions would be greatly appreciated!
Regards,
Jeff
vincaroo is offline   Reply With Quote
Old 05-27-2017, 05:46 PM   #2
Mollysdad's Avatar
Not all LEDs are dimmable.
Were yours sold as such?
I had some that would flicker, then shutoff.
Old 05-27-2017, 07:30 PM   #3
Chip and Jeff
ctcbcl's Avatar
1991 25' Excella
Atlanta , Georgia
Regardless, shouldn't his on/switch work?
Chip & Jeff
Fur-Children: Porter and Spencer
Atlanta, GA
ctcbcl is offline   Reply With Quote
Old 05-27-2017, 08:16 PM   #4
vincaroo's Avatar
1991 25' Excella
1995 34' Excella
Atlanta , Georgia
Both are correct. The first bulbs were not dimmable, but I would have been okay if the on/off switch had worked (it didn't). The second bulbs were dimmabke, but still didn't work either dimming or on/off so I have to think something is funky with my wiring job.
Old 05-27-2017, 08:47 PM   #5
1979 23' Safari
Wayland , New York
They might be polarity sensitive, switch the positive and negative.
Old 05-31-2017, 04:41 PM   #6
vincaroo's Avatar
1991 25' Excella
1995 34' Excella
Atlanta , Georgia
Yup... reverse polarity. I flipped my wires and it works perfectly. Thanks all!
12 volt
Dimming lights zestojo 2007 Safari 6 11-18-2012 07:39 PM
Lights Dimming tmsandberg Lights - Interior & Exterior 2 05-06-2012 10:55 AM
06' CCD low power - dimming lights, fans? bradk Batteries, Univolts, Converters & Inverters 9 08-09-2009 09:40 AM
weird noises and lights dimming slapshift Lights - Interior & Exterior 5 09-01-2008 05:59 AM
