08-13-2012, 02:02 AM
1975 Argosy 26
Des Moines
, Iowa
12 volt interior lights
I have power to bar.i have red yellow purple and blue wires coming out of the boxcould anyone tell me where they go? It's a 1975 argosy 26' . I have no 12 volt anything.semper fi andy
08-13-2012, 06:24 AM
Denton
, North Carolina
Can you post a picture?
Dan Brown Denton NC
08-13-2012, 07:03 AM
Princeton
, New Jersey
Are you saying the wires have been disconnected from the fuses and are just hanging free in the box?
If so make up a test lead using a Radio Shack fuse holder with a 10 amp fuse in it and connect it one at a time to each of the wires in question and then to power and try lights and other 12 volt circuits to find where they go.
Circuits most likely will include, lights, water pump, refig. 12 volt side
2004 Excursion 4x4
08-13-2012, 07:34 AM
1974 Argosy 26
Morrill
, Nebraska
You can also use a battery charger to test the circuits. Simply connect the black lead of the charger to a clean spot on the chassis, then use the red lead to test each of the circuits. A charger rated at 6 amps is more than adequate to perform the tests.
08-15-2012, 08:08 PM
1975 Argosy 26
Des Moines
, Iowa
the previous owner removed the old fuse panel and cut the wires. the wires are coming out of the floor. he put a paralax 7300 converter in and hooked it up to the old fuse box there are 4 breakers in the old panel and 3 breakers in th new one,with 10 fuses , the wires coming out of the floor and are red,yellow,purple,and blue.the red,yellow,purplewires look like #14 and the blue one looks a #12 or 10. i have power to the fuse bar. does anyone know what the color of each wire operates THANKS SEMPER FI ANDY
08-15-2012, 08:52 PM
Princeton
, New Jersey
Wires coming up from the floor may be the wires from the umbilical cord. Most interior wiring in an Airstream runs over head. If you have the standard 7 pin cord end this will give you the function of each wire.
Electrical Tips
Get a wire long enough to reach from these wire out to the male end of the umbilical cor and test each wire for continuity.
Do you see any wires coming to the panels from above?
2004 Excursion 4x4
08-16-2012, 05:45 AM
1974 Argosy 28
Fresno/Clovis
Here is how I wired my PD9260 and Parallax fuse panel. I did not trace the wires to individual lights and fans, but they all work.
Roger
08-16-2012, 06:43 AM
1977 Argosy 24
Milltown
, Wisconsin
If the wires you are talking about come out in the street side front, those are for the outside lights that connect to the tow car. At least on my 77 Argosy.
08-16-2012, 06:57 AM
1972 31' Sovereign
1979 29' Ambassador
west monroe
, Louisiana
I can't tell you where the wires disappear to, but I did have a similar problem and someone kindly wrote that I should check my main fuse holder near the Univolt. I had already checked the fuse and it was good, but I then I discovered that the fuse retainer was corroded. Once I sanded the contact surfaces, every was good to go and I got my 12 vlts back.
08-18-2012, 05:03 PM
1975 Argosy 26
Des Moines
, Iowa
Thanks everyone for your .The trailer plug end to the tow car works all outside lights, markers, stop, and turn signals what i don't have is 12 volt power to oerate the water pump,furnance,refrig,and interior lights. thanks again for your help. SEMPER FI ANDY
08-18-2012, 05:26 PM
Sioux Falls
, South Dakota
It's a big issue to settle on a forum with no pictures, no drawings, and no service manual schematics.
One thing I will write to is the very real possibility that one of the disconnected wires is used to power the breakaway switch that powers the trailer brakes in the event of a disconnection event. Having that switch connected under power and working the brakes could save somebody's kid if that trailer comes loose while towing. Nobody plans a loose trailer rolling into oncoming traffic at 60 miles an hour, but it happens.
Not having all the safety features connected and working is called neglect.
My abstract advise is to have all the exterior lights working, and to have the breakaway switch under power, tested, and working.
08-18-2012, 09:00 PM
1975 Argosy 26
Des Moines
, Iowa
All that stuff has been checked out and is working like it should!!!!!!!!!1i'm having trouble with the interior lights,water pump refrigerator and furnance. I don't need a lecture on saftey splitrock. Since i got out of us marine corps i've loged over 2 million miles over the road with no accidents. Saftey has always been my concern but thanks for your concern.
08-19-2012, 07:27 AM
1974 Argosy 26
Morrill
, Nebraska
Did you try my suggestion of using a battery charger to power each of the wires you mention? The pastel colored wires are typically used for the interior circuits. The wires in my '74 Argosy are in the rear of the trailer and do go into the floor. From there they must go up into the wall.
08-19-2012, 11:08 AM
1975 Argosy 26
Des Moines
, Iowa
that is where my wires are. i have not had a chance to try what you are talking about. te trailer is at a friends farm and the Iowa state fair is supposed to get over today. the traffic is terrible on university.this is the last day, i'll try monday and let you know. THANKS. SEMPER FI ANDY
08-20-2012, 04:27 PM
1976 Argosy 28
Tuscola
My 1976 looks something like this.
Purple:
Bath
Hall
Rear
Pink:
Pump
Front light
Furnace
Yellow:
Kitchen lights
