Old 02-09-2014, 04:02 PM   #1
BeachHouse's Avatar
2005 25' International CCD
Lilburn , Georgia
12 volt ground
I want to add a step light. I have an exterior led fixture. I can get 12 v power from the switch bank near the door. But there is no 12 volt ground near by. I can get a ground from a nearby 120 v outlet, or by just grounding to the trailer. What is better? And, if I use the 120 volt source, should I use the neutral or the ground wire?
BeachHouse is offline   Reply With Quote
Old 02-09-2014, 04:12 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Just ground it to the trailer.
Old 02-09-2014, 04:17 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Just a quick note: NEVER use a 120VAC neutral as a 12VDC ground! Homes have the neutral and ground bus bars bonded at the breaker box, but this is NEVER DONE IN RVs as you will have energized the frame and or skin of your trailer!!!
While the ground of your AC circuits connect to your frame or chassis, the neutral will kill you if it is!!!!! Use the frame for a ground for your DC load and stay away from your AC circuits!!!!!!
Old 02-09-2014, 04:41 PM   #4
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Your question scared the _____ out of me; I am glad Lewster provided the answer.
Larry
lsbrodsky is offline   Reply With Quote
Old 02-09-2014, 06:05 PM   #5
BeachHouse's Avatar
Lilburn , Georgia
Old 02-10-2014, 06:45 AM   #6
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Side note, even if you miraculously avoided getting electrocuted, you'd trip every GFCI in your trailer. The GFCI would register the 12v current "piggybacked" on the ac circuit as if it was current leakage on the 120vAC side.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 02-10-2014, 07:42 AM   #7
BeachHouse's Avatar
Lilburn , Georgia
I knew of these issues. That is why I asked. I haven't even started that project, just getting my ducks in a row. Again, thanks for the help.
12 volt
No 12 volt power at panel Jim Flower Batteries, Univolts, Converters & Inverters 17 02-06-2014 05:55 PM
Is it okay to have 12 volt light grounded to skin or frame.. Bill M. Lights - Interior & Exterior 1 09-14-2011 02:27 PM
12 volt panel location kmoore Electrical - Systems, Generators, Batteries & Solar 5 08-24-2011 09:45 PM
Volt meter on battery box Denis4x4 Batteries, Univolts, Converters & Inverters 0 07-14-2011 12:56 PM
1974 Sovereign 12 volt battery pigtail Shamock Batteries, Univolts, Converters & Inverters 3 06-24-2011 05:08 PM
