Old 08-29-2008, 09:43 AM   #1
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
12 V outlet
I have been puzzled by this for some time (not hard to do!); there is a 12V outlet above the nightstand in our bedroom (similar to the one up front for near the television hookup...yet it does not seem to provide 12 volts? I plugged a batter charger into it and it popped the charger so I know it is supplying voltage. I have also plugged a DVD player into and it does not power the DVD player (which may have a built-in safe guard?).
What is this outlet for?
We do not carry a televison in our AS, is this something to do with the antenna booster?
I have not tested it with voltage meter...
It seems to supply voltage but not the correct voltage?
Everything else in our Excella works fine, 110 and 12 volts...
There is a 12 outlet in the bathroom also, that work fine.
Thanx, Bill
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 09-27-2008, 10:46 PM   #2
TCM1's Avatar
1975 31' Sovereign
Drasco , Arkansas
Me too.
I've noticed the same thing in my 75 International. It's the only 12 volt outlet I've found, but it's in the same location you described. Anybody have an idea what's going on?
TCM
TCM1 is offline   Reply With Quote
Old 09-27-2008, 10:59 PM   #3
Ifihadtime's Avatar
1981 27' Excella II
Lynnwood , Washington
I would put a volt meter on it. Maybe at some time a PO had it out and wired it backwards. The shell (casing) should be ground and the post in the center positive.
Ron
81 Excella II
I am always doing that which I can not do, in order that I may learn how to do it.
Ifihadtime is offline   Reply With Quote
Old 09-27-2008, 11:02 PM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
My trailer has 4 (I added one) and they all work the same. I have run my 12 volt fan and cell phone charger from all of these with no problems. Looking at the wiring diagram there is nothing special with these connectors.
Richard
Old 09-28-2008, 12:33 PM   #5
1 Rivet Short
1989 25' Excella
Thanx-I will check that...
Bill
mystery outlet jpeterman Electrical - Systems, Generators, Batteries & Solar 8 08-08-2008 08:06 PM
T V outlet Gene Wissink 1974 - 1979 Sovereign 0 01-19-2004 07:56 AM
Electical outlet Alex Electrical - Systems, Generators, Batteries & Solar 3 11-30-2003 08:50 AM
Looking for Outlet Cover 63flyingcloud Electrical - Systems, Generators, Batteries & Solar 3 06-30-2003 11:30 AM
30 amp outlet john hd Electrical - Systems, Generators, Batteries & Solar 20 02-26-2003 01:54 PM
