Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 07-01-2009, 01:13 PM   #1
Profile:  1973 27' Overlander
Loganville , Georgia
1 running lights hot wire is not getting a current.
I have finished up with all the lights all over the interior and exterior. I Have one red running light up high in the back on the drivers side which won't work. The red hot wire coming out of the trailer is not holding a charge. I am not going to take the interior apart to fix a wire. Does anybody else have a unique way of helping me solve this problem.
Brian
Brian & Adrienne
Lothlorian is online now   Reply With Quote
Old 07-01-2009, 01:41 PM   #2
mello mike's Avatar
Profile:  1972 31' Sovereign
Phoenix , Arizona
Images: 14
How about tapping into an adjacent light?
Sterling - 1972 Sovereign Intl (RB)
Eddie - 2003 Ford Excursion (6.0L PSD)
Prodigy Brake Controller / Equal-i-zer Hitch / Honda EU2000i x2
Airstream Life Contributor
WBCCI 4CU #5661/AIR #5661
My Refurb Blog: UPDATED!!
http://mellomikesairstreams.blogspot.com/
Part wanted: 70s Kitchen Counter Unit
mello mike is offline   Reply With Quote
Old 07-01-2009, 01:42 PM   #3
Profile:  1977 27' Overlander
1963 19' Globetrotter
naples , Florida
I hope I`m thinking of the correct lay out,can you enlarge hole at center line and snake a line over from there? Dave
easyride is offline   Reply With Quote
Old 07-01-2009, 06:09 PM   #4
I will check both your possibilities tomorrow. My pneumatic rivet gun bit the dust. I don't want to drill out the rivets of the light until I get a new gun to see what is wrong. Tomorrow I will go after this problem.
Brian
Brian & Adrienne
Old 07-02-2009, 12:40 PM   #5
I pulled the light and checked the wire again and there isn't any current going through it. I used a volt meter which gave me no indication of power. I also pulled pictures off of this forum that had my type trailer with the inner walls pulled out of the bathroom. I could see the wiring for the running lights. The wires seem to run along the top part of the bathroom window and then shoot up to the light. I have no idea how to get the wire out to fix it. I really do not want to run an outside wire and I am not going to take the inner wall out. I guess I will leave it as is.
Brian
Brian & Adrienne
Old 07-03-2009, 01:20 PM   #6
naples , Florida
We didn`t mean to run wire on outside,fish it between the walls from the other light.Dave
Old 07-03-2009, 02:21 PM   #7
Jim & Susan's Avatar
McDonough , Georgia
Brian, one thing I completely forgot to mention last night when we were talking. The red wire that attaches to the light socket connects to a green wire inside the shell with a crimp connector. You might try to gently pull the red wire and see if you can pull that connector out and test from the green wire end. I have a picture of that wire, but it's not a really good picture. Let me know if you want me post it here.
If you can't fix it with a hammer or a rivet, you have an electrical problem.
www.nesa.org
Air No. 6427
Ground wire getting hot????? 86Scotty Batteries, Univolts, Converters & Inverters 23 03-15-2009 03:44 PM
Gauge of wire used for running lights campngirl Lights - Interior & Exterior 6 08-21-2007 09:05 PM
New brakes running hot! Buttercup Brakes & Brake Controllers 18 06-27-2007 01:49 PM
Running Lights/Backup Lights 85 Sovereign GRAYMAN Lights - Interior & Exterior 7 08-10-2004 09:54 AM
Running Hot Starman Airstream Motorhome Forums 6 06-27-2002 10:36 AM
