Old 07-24-2009, 10:53 AM   #1
stowaways's Avatar
2007 27' Safari FB SE
1969 31' Sovereign
Ft. Worth , Texas
Why does the water back wash into the tub?
Not sure if the terminology is right, but here's the idea. We don't have a gray tank in our '69 Sovereign, so we keep a small red hose attached and slowly let the gray drain away (only when and where permissible, of course).
When we use the bath sink, it drains fine. When we use the shower drain, eventually it drains okay. But if there's any water in the tub whatsoever, and you use any other sink, the water backs up into the tub. Shouldn't it all just drain out the drain out valve?
We've cleaned and flushed the water lines, hot water tank, plunged, etc.
Any ideas?
PS once we got over the boiled out battery crisis, we're actually enjoying the renovation again. All new screens last night! Yay! And the new blinds and cushions are on the way.
Thanks for the helpful tips and sharing in our fun!
stowaways is offline   Reply With Quote
Old 07-24-2009, 11:09 AM   #2
Any ideas?
The tub water drains to the same place as the sinks.
Be patient, and wait 15 minutes or so, since your using a small hose.
If your flushing away a lot of water, it will back up into the tub, since thats the lowest part of the system, but that will drain away also.
Old 07-24-2009, 11:19 AM   #3
SteveH's Avatar
Common Sense , Texas
This is only my idea, but it sounds like the water is not able to drain thru the "small red hose" fast enough.
I would try the same situation with a large sewer hose and see if it changes.
Old 07-24-2009, 11:22 AM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Check your roof vents
Old 07-24-2009, 11:25 AM   #5
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Funny thing water - it can make it's own decision and seek it's own level. I'm guessing that the red hose you're using to drain the gray water is small enough that water is backing up into the tub. When the tub drains, it will fill the drain line completely since the hose is the restriction. Then, when you add more water to the drain line (like from the bathroom sink), the water will go to the lowest place possible. In your case, the bathtub. And since the drain plumbing is already full of water, it will flow to the bathtub quite easily. So even though you're draiing the bathtub via the hose, the water from the higher sink will flow into the drain, and backup into the tub, because the hose is already full of water draining out. You have two 1 1/2" or 1 1/4" drains trying to go out a single 3/4" or 1/2" hose. The tub is acting like a gray water tank and holding the water until it can drain out of the hose.
Chris
Chris
Minno is online now   Reply With Quote
Old 07-24-2009, 11:28 AM   #6
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
My guess is that it is the laws of physics rather than a problem in the trailer drains.
I would bet that the "small red hose" is the problem. It most likely is restricting the flow to a rate of less than the other drains, especially in combination. In that case, the water takes the path of least resistance ........ into the tub, the next lowest point.
To check this theory, remove the red hose and the cap it attaches to so you have a full 3" drain with no restrictions. I am guessing you have this option from the setup on my trailer. Then drain some sinks and shower in ways that previously cause problems and see if the problem is reduced or eliminated.
I, too, have no grey tank and use your same method. When I dump my kitchen sink through my "small black hose" it will sometimes back up in the tub. My cure is to slow the sink drain slightly so I have no backup. Hope this helps.
Sam
samb is offline   Reply With Quote
Old 07-24-2009, 11:30 AM   #7
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
I think you will find that the sinks flow into the drain between the tub and the final exit. If water is backed up into the tub, the exit drain is also full of water, so any water put down the sink drain will flow to the lowest point, which is the tub.
I once was hooked to our large "Blue Boy" with a small hose and had the shower water back up into the tub. The Blue Boy was empty, but I had not opened the drain cap, so air could not exit the Blue Boy as water entered. As soon as the air pressure in the Blue Boy built up, the water could no longer enter it and backed up. It doesn't take much to cause sink water to back up into the tub.
Old 07-24-2009, 02:16 PM   #8
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Just make sure the black tank valve stays closed. You don't want any of that coming up in the tub....
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-24-2009, 05:35 PM   #9
HowieE's Avatar
Princeton , New Jersey
Images: 12
Sounds like you are building pressure in the gray water system. This could be because of the Small Drain hose and water is coming into the system faster than it can drain. As mentioned above try a full size drain hose or find a spot where you can just open the drain directly to the ground and try it there.
If you still have a problem depending where the vent is tied in flush the roof vent and try again.
2004 Excursion 4x4
Old 07-24-2009, 06:25 PM   #10
airstreamjudy's Avatar
1968 24' Tradewind
Largo , Florida
Lumatic - tell us about the "roof vents". What's your theory?
JudyW
airstreamjudy is offline   Reply With Quote
Old 07-25-2009, 09:48 AM   #11
stowaways's Avatar
1969 31' Sovereign
Ft. Worth , Texas
thanks all... we suspected the red hose. Will try experiment with slinkie and see if we get a different result! : )
Old 07-25-2009, 12:47 PM   #12
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
Thoughts to consider
We've learned in previous posts that water seeks it own level. Is the end of the red hose lower than the tub? Does the red hose go over a small hill, then back down? This would create a drain trap which would cause more resistance in draining.
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Hot water to sink but not tub? ovrteakettle Water Heaters, Filters & Pumps 1 07-23-2009 01:07 AM
Water comes out the back bumper! 1972 Argosy Pneumatos Fresh Water Systems 6 06-22-2009 07:47 AM
Is there a back flow valve on my water pump? Mrcrowley Fresh Water Systems 5 04-25-2009 10:06 AM
Need help removing back closet and tub. drowe42 1966 - 1968 Safari 0 04-04-2009 04:56 PM
Black water back up Ketchum Waste Systems, Tanks & Totes 8 06-13-2008 09:58 AM
