07-25-2015, 10:22 AM
2008 25' Classic
Full Time
Why 25FB Shower Pan has a Seat?
I've always thought the shower floor had the half seat because of the wheel well but when looking outside the trailer the wheel well finishes under the fridge not even near to the shower. Does AS need to do this for some plumbing or wiring? It would sure be nice to take a shower without that seat in the way.
The 25RB has a full seat in the shower. Must be more difficult to take a shower.
Kelvin
07-25-2015, 10:28 AM
Corona
Kelvin
Kelvin.
The shower seat provides a place to sit down, so you can better scrub you ankles and toes.
It also helps saving water when 2 people shower together, along with other fringe benefits.
Plus on many models, it does go over the top of wheel well covers.
07-25-2015, 10:35 AM
Retired.
, At Large
Kelvin
The seat-type shower pans can be used in other models where the wheelwell or outside shower would interfere with a full-stall shower. It makes more sense if there were only a couple of different showers than one for every single model.
07-25-2015, 10:45 AM
2008 25' Classic
Full Time
So if I wanted to get an Airstream renovator to put in a shower pan that was full size then it shouldn't be an issue except for how to pay for it.
Kelvin
07-25-2015, 10:48 AM
Biloxi
, Mississippi
My 23 Safari also has a shower seat. Use it all the time. It is at the aft of the trailer, no where near wheel well and the the space underneath has no exterior access. Seems like waste of good storage space to me.
MICHAEL
07-25-2015, 10:54 AM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
That's fixable. Cut a hole in the top to provide access, use a hinged plywood cover as a new seat (waterproofed, of course), and make sure you put a gasket around the hole you cut to prevent water penetration while showering. Inside the seat would be a great place to store cleaning supplies.
07-25-2015, 12:17 PM
Corona
Kelvin
Kelvin.
Most likely the labor will cost far more than the shower pan.
07-26-2015, 10:29 AM
Costa Mesa
I believe the major reason is because of the necessarily small space. Most of us could not get to our lower legs & feet without the seat.
07-26-2015, 11:04 AM
2008 25' Classic
Full Time
I never used the seat. Sometimes I'll lift my legs on it one at a time to clean my feet but AS doesn't really need to make the seat that big to do that. If it was half as long it would be easier to stand in the shower. Having the seat extend all the way across like in the 25RB must make it impossible to turn around without your shoulders hitting the shower door and making you loose your balance.
Kelvin
07-26-2015, 11:40 AM
2002 19' Bambi
Lafayette
Several years ago we installed a screw-out deck plate (for a boat) on the side of our seat. It gives us water-tight access to that formerly unused space as well as a nice inspection port to see if there are any leaks associated with either the shower or our Bambi's exterior.
Tim
07-26-2015, 12:58 PM
2012 25' Flying Cloud
Battle Lake
Kelvin
After hundreds of showers in our 25RB we see no problems with the shower seat. None.
If looking for a new Airstream the shower seat as designed is a complete non-issue, I can't stand upright next to the inward curved wall anyway, and I like the seat for washing my feet. The showers in all Airstreams are small, but how much of our day do we spend there.
Doug and Cheryl
07-26-2015, 04:12 PM
2010 27' FB Classic
N/A
Tim
Hey Tim,
Do you happen to have a picture of your modification you could post?
07-26-2015, 04:24 PM
1960 22' Safari
in the wilderness
, The great Mojave Desert
Over 6 foot here. Seat makes the shower in such a confined space easier.
I'd rather be boon docking in the desert.
WBCCI 3344 FCU
AIR# 13896
CA 4
Yes, we have courtesy parking for you. About an hour North of Los Angeles.
07-26-2015, 04:29 PM
2005 28' Classic
Moutain Center
From a women's point of view.....we shave our legs, so having a place to sit helps! Also, my husband and I have made a habit of using campground showers rather than our own - for several reasons...less grey water to dump, no need to dry out/clean shower stall afterwards and we use our shower for our cat litter box, as well as storing other items. We do wear sandals in campground showers and that's a bit of a pain - but no big deal.
07-26-2015, 04:36 PM
AIR #6370
2001 27' Safari
Bella Vista
, Arkansas
Since the shower stall is reasonably generic and used in most if not all A/S, I'm sure i"ve seen the water heater recessed under the shower seat. Of course all this is dependent of the age and floor plan of the trailer.
07-26-2015, 05:01 PM
From All Over
One thing that helps with that, wax your shower stall, all but the floor (textured floors are hard to wax). Automotive spray wax is easiest. Water beads up and runs to the floor rather than clinging to the walls. If water beads up but doesn't run to the floor, a tap on the wall is usually all it takes to knock the water droplets loose. I picked up that idea years ago from a book on sailboat maintenance, and I've used it ever since. I usually wax mine twice a year.
I've just about decided to start waxing the inside of the fridge to make it easier to clean, too.
07-26-2015, 05:29 PM
2009 28' International
Pacific Palisades
No full seat--please!
I our 28' 2009 International, the shower seat goes all the way across the back. This effectively cuts the shower size in half. It is almost impossible to shower without banging elbows. For those who need the seat, half seat should be enough, but for those of us who don't, oh please get rid of the full bench! Not strong enough to wash one foot at a time without a bench? Gently lean into the side of the shower to take much of your weight that way balancing against your grounded foot, bend the other leg at the hip and knee and--no problem!
Oh well--that's what makes all of this so much fun!
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario
, Ontario
Save water; shower with a friend.
07-26-2015, 05:57 PM
Salem
, Oregon
Hi, if my shower didn't have the seat, I would have to use twice as much water in the tub to give Dusty a bath. And that's just wasteful.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
07-26-2015, 06:33 PM
2008 25' Classic
Full Time
I'm surprised more like the shower seat then don't. I just want to be able to spread my legs out in a normal stance to face the shower head. None of the houses I've lived since I can remember had seats in the shower stall.
I wonder if a fiberglass expert could cut the seat down by half and then patch it and blend it in to match the rest of the pan.
Kelvin
