Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 06-08-2012, 07:17 AM   #1
ts8501's Avatar
2022 25' International
Savage , Minnesota
Which Toilet is This?
I need to replace the flush valve seal in this toilet. Who is the Manufacturer? I need to figure out how to take it apart to get to the seal. It no longer holds water in the bowl.
Name:	rv toilet.jpg
ID:	160377   Click image for larger version
Name:	rv toilet 2.jpg
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
https://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 06-08-2012, 08:52 AM   #2
1974 Argosy 20
Kooskia , Idaho
It looks like a Thetford "Bravura" to me. The curved piece under the foot pedal and the general shape is the same as the one I put in my Argosy 20' a few years ago. Mine had a manufacturing defect and Thetford replaced the bottom seal you have which is leaking. They sent me the part, and I put it in. This was quite a while ago, but as I recall, once the toilet was removed (bolts under that pedal cover and in the rear I believe) the slide valve on the bottom just unbolted and could be replaced. However, that is very general information from my fuzzy memory, but I don't recall that it was a huge job. The Bravura is still made and marketed. You might find the cost of a total new one was close to the repair parts cost. I would check first in any event.
