Old 08-20-2011, 03:01 PM   #1
Beaufort , North Carolina
What years and models of Airstreams have a bath tub?
Hi Guys,
I am in search of an airstream, that has a bath tub. I'm looking for a longer 30+ foot model and have gone crosseyed trying to figure out what model/year combinations came with the bath tub!
Thanks much,
Zach
ZachEakes is offline   Reply With Quote
Old 08-20-2011, 03:10 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Welcome to the forums. I know the 31' Sovereign and Excella models had bathtubs from at least 1969-1980.
Old 08-20-2011, 03:31 PM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Zach!
Welcome to the Forums!
Starting sometime in the early-to-mid-1960s, most of the 24' and longer Airstreams had a modest-sized bathtub in their rear bathrooms. The same would hold true for all first generation Argosy travel trailers . . . 24' and above have modest-sized bathtubs in their rear bathrooms. I am not aware of any Airstreams that offer a mid-bath with a bathtub . . . it seems that the only bathtubs offered were in the rear bathrooms (I could be mistaken on this as I have never been a fan of the mid-coach-bath floorplans -- so haven't been paing close attention).
Good luck with your investigation!
Kevin
P.S.: You might find more information about floorplans of a partiular coach that you might be considering through this link.
Kevin D. Allen
AIR #827
Old 08-20-2011, 04:42 PM   #4
Someday'59's Avatar
Powder Springs , Georgia
Images: 18
My '59 Overlander has a bathtub.
~Lynnetta
my restoration & travel blog:
http://someday1959.blogspot.com
Someday'59 is offline   Reply With Quote
Old 08-20-2011, 06:01 PM   #5
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Porcelain Clawfoot model? Did it also come with the backscrubber? LOL! Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 08-20-2011, 06:08 PM   #6
Silverwanabe's Avatar
1967 26' Overlander
Winston Salem , North Carolina
Images: 107
Hi,
I know for a fact there was a 32 ft rear bath w/ tub in 90.
There was a 27ft rear bath w/ tub in the mid 80's.
Rear baths were common 1980 back to the 50's.
I think side baths did not begin till the 73 model year.
Good luck in your search.
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
Old 08-20-2011, 06:25 PM   #7
Central , Mississippi
Both my '77 and my '63 have tubs. My '91 34' does not.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 08-20-2011, 06:34 PM   #8
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
maybe Argosies bigger than 24'?
@Overlander64: My '75 Argosy24 just has a shower pan about 5" deep in the rear bath. I don't know if it's a year issue, a feature that was only on larger-than-24' Argosies or some sort of option. I have the original "window sticker" sort of list of options on mine from when it was originally sold, and there's nothing mentioned about any options in the bath, but it mentions the optional dinette so I assume the shower pan is standard for mine.
It's probably moot though, since the OP is looking for bigger trailers. Personally, I prefer the shower pan, but then again I prefer just a shower at home too.
David
Old 08-20-2011, 07:37 PM   #9
Cantrell's Avatar
1988 34' Limited
1960 24' Tradewind
Mt. Pleasant , South Carolina
Our 1988 34' has a full bathtub--we have the walk through bath. The tub is 4' long and sits over part of the wheel well so there is a shelf at the wall about a foot higher than the bottom of the tub. Gives you a place to sit all your stuff for a bath and makes the shower fairly spacious for a travel trailer.
Here's a link to the 1988 floorplans--our plan is in the top, right corner. Good luck in your search.
http://service.airstream.com/files/l...87473118e8.pdf
Bill Cantrell
AIR 24338
TAC SC-1
__________________________________________________
Easily distracted by shiny objects.
Cantrell is offline   Reply With Quote
Old 08-20-2011, 07:46 PM   #10
Cantrell's Avatar
1988 34' Limited
1960 24' Tradewind
Here's a link to many of the models made by Airstream sorted by decade. Lots of floorplans. May help you to sift through and narrow down what you are looking for.
Airstream, Inc :: Travel Trailer Specifications
Bill Cantrell
AIR 24338
TAC SC-1
Old 08-20-2011, 07:51 PM   #11
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 183
Good catch . . . I was working from memory without checking my literature . . . made the assumption that the Argosy 24 used the same bath tooling as the similar model TradeWind. I knew that the rear door model had a shower to make the bath more compact, but it looks like the standard Argosy 24 floorplan always had a shower . . . at least the three years of literature that I sampled before writing this message.
Kevin
Kevin D. Allen
AIR #827
Old 08-20-2011, 08:08 PM   #12
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
And a chamber maid for the black tank?
Phrunes is offline   Reply With Quote
Old 08-21-2011, 04:52 AM   #13
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
81 excella II. Bathtub. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 08-21-2011, 01:03 PM   #14
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
And don't forget the attendant providing cologne and body sprays! Please remember to tip generously!
Interesting read on the Eco-boost Denis4x4 Tow Vehicles 4 08-21-2011 11:58 AM
Differences between AS & Argosy billy1davis All Argosy Trailers 23 08-05-2011 08:00 PM
Excella Designation? Phrunes Off Topic Forum 8 04-28-2011 07:07 PM
Quality of construction late '80s early '90s trailers MrBeast General Repair Forum 7 03-06-2011 07:54 PM
