Old 10-21-2014, 01:35 PM   #1
Alcoa Roller's Avatar
Dallas , Texas
What toilet flange
Well folks I am re moding the bathroom and finally getting to the toilet. I removed the old flange today and below is what I am left with. What is in the tank is rusted and i see no threads. You will also notice that the metal piece in the tank sort has a bowl shape. I will be putting 1/2 ply on top of the fiberglass surface that the toilet used to rest on. It will now rest on the plywood. I noticed some flanges at Vintage trailer but they all seem to want to thread to something. BTW my rig is a 63 Overlander. Please help. If the crapper is down the brain soon follows.
ID:	224850   Click image for larger version
Alcoa Roller is offline   Reply With Quote
Old 10-21-2014, 06:40 PM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
I don't know what the black tank design looks like. Being a 63 trailer it is not likely polyethylene.
Here is what I used. I purchased this flange from Inca Plastics in California. They make just a lot of tanks for the RV industry. This flange fits in a rubber grommet that is a press fit around the hole in the tank.
As I recall I used about a 3 1/2 inch hole saw to cut the hole in the tank using my flange hole in the bath as the drill guide. The tank has about 3/16 thick walls. The grommet is pressed into the tank, the tank mounted to the trailer, and the flange lubricated and pressed into the grommet. I had two 5/8" layers of plywood between the tank and the floor covering. It would be difficult to develop a fange to tank interface leak.
I liked Inca Plastic's design with the flange and grommet.
David
Name:	1312 Plumbing New Holding Tanks.jpg
ID:	224865   Click image for larger version
Name:	1405 Bath Toilet Flange Installed.jpg
Old 10-21-2014, 06:56 PM   #3
Dallas , Texas
Thanks DB, Ill check them out. My tank is fiberglass. Its original. Problem is I have the iron insert already in the hole that I am having to deal with. The hole in the metal piece is slightly less than 3" i think I need something that will be like a funnel that leads from the flange on the surface down into that hole. I have had some leaks and now know why.
Old 01-19-2015, 02:46 PM   #4
1955 22' Safari
Laredo , Texas
VTS has lots of parts on their site to handle this problem. They are also super knowledgable and helpful on the phone. Call them!
55AS is offline   Reply With Quote
Old 01-19-2015, 02:47 PM   #5
1955 22' Safari
Laredo , Texas
Toilet Floor Flanges
Black Tank-To Flange or not to Flange? Mrwaterway Waste Systems, Tanks & Totes 4 12-02-2009 09:02 AM
Need flange for my toilet-b/w tank 68Glbtrotter Waste Systems, Tanks & Totes 7 01-24-2006 08:07 PM
Toilet Flange won't unscrew!! mello mike Sinks, Showers & Toilets 11 07-11-2005 08:34 PM
HELP - Removing Toilet Flange Joe Z Sinks, Showers & Toilets 4 07-12-2004 10:10 PM
Toilet Flange Sneakinup Sinks, Showers & Toilets 16 06-30-2004 03:16 PM
